95 Geo Tracker exhaust system. - Suzuki Forums: Suzuki Forum Site
Old 08-04-2013, 09:43 AM   #1 (permalink)
Gord is on a distinguished road
Default 95 Geo Tracker exhaust system.
Next on the list for my 95 16 valve 4X4 geo Tracker is the exhaust. I have repaired it for the last time. The section that comes down from the manifold and connects to the catalytic converter, as well as the catalytic converter to the muffler and back are shot.
I was looking at this: Direct Fit Catalytic Converter by Maremont not for Sale in California 29570 | eBay
Anyone here try this method. Converter built right in to the pipe?
Any thoughts are appreciated.
Gord is offline   Reply With Quote Quick reply to this message
Old 08-04-2013, 11:06 AM   #2 (permalink)
jholl is on a distinguished road
You should check you exhaust manifold to be sure which exhaust pipe you have. The one in the link you showed is 2 pipes side by side coming down into one pipe before the catalytic converter. I have a 94 Geo Tracker that uses that pipe. But my 95 Geo Tracker is a single pipe coming down to the cat. Just a word of caution.
jholl is offline   Reply With Quote Quick reply to this message
Old 08-04-2013, 11:15 AM   #3 (permalink)
Nice catch with a rather poor pic.
Can't beat the shipping either. FREE!
Max is online now   Reply With Quote Quick reply to this message
Old 08-04-2013, 11:25 AM   #4 (permalink)
big ed is on a distinguished road
Does anybody think that without that flexible joint at the CAT you might be putting unwanted stress's on the manifold ?
1998 CHEVY TRACKER/ USA/ 2WD/ 16V/ 3 SPEED AUTOMATIC/76000 MILES.... 1999 DODGE 3500/ 5.9 CUMMINS/ 5 SPEED MANUAL/ US GEAR OVERDRIVE/ 231000 MILES.... 2003 CHEVY MALIBU/ 63000 MILES (Also known as Mr. Magnum to my friends)
big ed is offline   Reply With Quote Quick reply to this message
Old 08-04-2013, 11:28 AM   #5 (permalink)
IF an OE install was equipped with one, then I'd say yes!
Old 08-04-2013, 12:13 PM   #6 (permalink)
I'll climb under there this afternoon. I do remember seeing a joint with a couple springs on it. Everyting in that area is so rusted, it's hard to tell what's there. I do believe there are springs up by the manifold as well. Maybe that will take some of the stress.
I will also see if it is a two pipe to one system, as I was wondering about that myself.
Old 08-04-2013, 01:46 PM   #7 (permalink)
m000035 is on a distinguished road
If you saw springs by the manifold, it is the one big pipe down pipe and not the two small pipes. The two small pipe downpipe is connected with three bolts/studs and no springs. The larger single pipe with springs seems to be later design, but implemented at different times in different markets.
I suspect the lack of "flex sections" would contribute to manifold cracking.
Mike
Hillsboro Oregon 97124
1996 Sport Kick, 1.8L, 4 speed auto (Resurrected... current driver)
1992 4 door Kick, 16v 4 speed auto (kid's driver)
1989 Kick 2 door Tin Top (Basketcase/Project)
1994 Kick, 2 door, 8v, Auto, 2 wheel drive, soft top. (Project Parts donor)
-- Plus 3 70's GMC motorhomes (You seen "Stripes" or "Anchorman 2"?) and a late model Malibu named "Boo."
To follow my Projects see: http://m000035.blogspot.com/
m000035 is offline   Reply With Quote Quick reply to this message
Old 08-04-2013, 01:57 PM   #8 (permalink)
I would be carefull you don't wind up with one for a 8v.
Old 08-04-2013, 02:04 PM   #9 (permalink)
FWIW, my GV employes BOTH a corrugated pipe "flex" section AND the spring loaded donut gasket joint. There's a lot of movement potential to contend with there.
Old 08-07-2013, 08:17 PM   #10 (permalink)
Thanks for the advice. Mine is one big pipe, not two. And the whole thing about stressing the manifold makes perfect sense.
Nice to have a place to bounce ideas around.
