transfer case leak - Suzuki Forums: Suzuki Forum Site
Old 06-20-2013, 10:07 AM   #1 (permalink)
Tmrohyn is on a distinguished road
Default transfer case leak
hello again
my crossmember thats hold the transfer in place is full of oil dripping all over the place.
the front shaft and the rear shaft are clean, its apper to leak between the transmission and the transfer.
i suspect the oil seal in the transfer that prevents from oil dripping to the splice between the transmission and transfer.
i need a part number or dimenssion for this part (oil seal inside the t case) - cant fint at fel pro.
can i remove the transfer case without removing the transmission ?
suzuki vitara 1997 1.6 JLX 16v 4X4
ISRAEL
Tmrohyn is offline   Reply With Quote Quick reply to this message
Old 06-20-2013, 11:50 AM   #2 (permalink)
is it possible that oil drips fro bellhousing to the crossmember ?
ISRAEL
Old 06-20-2013, 11:58 AM   #3 (permalink)
aquanaut20's Avatar
The arrow is pointed at the rear transmission mount... Check the front out put shaft seal... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
99 Tracker, 4dr, 4x4, 2L DOHC, auto 200k
Old 06-20-2013, 12:47 PM   #4 (permalink)
Section Moderator
You may want to clean up the area to really look to see where it's leaking from. Do you have the 4 speed auto tranny? You may also want to confirm that you are leaking tranny fluid (red) and not oil.
'61 NSU Quickly - 150mpg
Security Question
