Kick 16V bogging - Suzuki Forums: Suzuki Forum Site
Old 02-21-2013, 03:46 PM   #1 (permalink)
Craig_c is on a distinguished road
Default Kick 16V bogging
First post here...so Hello!!
I have a 93 Sidekick JX 16V I just purchased. I have a couple issues.
While crusing at a steady speed it will start to bog. If I go ahead and give it more throttle, it will just hit and pick up and go on. I do not think it is a throttle position issue, as I payed attention to it, and depending on how bad the "bog" is or how long I let it bog down, the more thottle I have to give it to get it to pick back up.
Also, when accelerating, it kinda picks up and down as the RPM climbs. Like the power is not smooth through the RPM range under full or heavy throttle acceleration.
What all I have done;
Complete tune up (cap, rotor, plugs, wires)
New timing belt
New O2 sensor
Cleaned t-body
Cleaned Mass Air Meter
I cannot get the engine light to flash at all. The light is not on, but it wont even flash the all clear to me by jumping the terminals.
I pulled the vac line going to the fuel press. regulator, no fuel is dripping out, but not gonna say it isnt leaking a little. I have a Snap-On Solus but it does not have Suzuki in it....so for now a scanner is out.
Craig_c is offline   Reply With Quote Quick reply to this message
Old 02-21-2013, 03:50 PM   #2 (permalink)
I guess I should say, that all other times, the engine runs great, nice and smooth, idles smooth. I do belive it is running a bit rich. I did not clean the EGR, but putting a vacuum on the line at idle does make the engine run bad, so its not completly plugged up.
Old 02-21-2013, 04:19 PM   #3 (permalink)
Cobb is on a distinguished road
Maybe previous owner was a hypermiler and hooked up egr backwards? If you disconnect egr it otherwise runs ok?
95 sidekick ljx 4wd 5 speed 16v
235/75r15 yoko touring s
1.5 wheelspacers/curt hitch
3tech 5 degree cam advance
New shocks and HR lowering springs
Spare tire, roof rack delete
Cobb is offline   Reply With Quote Quick reply to this message
Old 02-21-2013, 04:45 PM   #4 (permalink)
As far as I know, the EGR should be closed at idle. I always knew a way to test EGR operation was to put a vacuum on the EGR at idle to see if it effects the engine....which it does.
Old 02-21-2013, 05:56 PM   #5 (permalink)
Just figured out the bulb for the engine light is blown, swapped it out and got;
Codes 14, 15, 24, and 34. Im gonna say the 34 code is my bogging issue. My speedo doesnt work, likely causing the 24.
Codes 14 and 15....my temp gauge reads very low. If I ground the wire it pegs out hot, as it should. I swapped out the sender and it still reads low.
I guess I got myself a basket of worms!
Old 02-21-2013, 06:58 PM   #6 (permalink)
One way to sell a used car. We had a news article on tv about it.
Old 02-21-2013, 07:05 PM   #7 (permalink)
May not be a basket of worms. Only 4 codes. Clear them and try again, one code can trip another.
The vehicle relies on the speedo working to run correctly as the ECU takes readings off that. A couple of users with running problems have noticed them disappearing after fixing their speedo.
What does your temp gauge read at? If it reads anywhere around 1/4 to 1/3 of the gauge that is very normal.
Edit: Actually since it is throwing temp codes it doesn't matter the gauge reading. Check and make sure the thermostat is in the right range.
Escudo, '93, 4 door, 16v, 4 spd Auto trans, 4WD, Auto locking hubs
1994 Isuzu Pickup 2wd 5 speed short bed
Scudo is offline   Reply With Quote Quick reply to this message
Old 02-22-2013, 12:49 PM   #8 (permalink)
xxx
a real tune up but no fuel filter , sadly............
the engine goes to limphone on most those.
rich as hell. retarded ignition , rpm limited and red hot exh.
so whats new there, repair the broken parts?
no 14 means the ECT wires fail off, (or the ect IS totally burned open inside) pick one. instant limphome 2.
15 means the ECT shorted, so the 2 wires are bare and twisted together.
might be old stored codes, pull DOMe fuse and drive 20 miles
and see if it comes back if does < ECU NEVER LIES its a hard fail.
the dash gauge is just a toy ,it has nothing to do with ECU. at all.
only an IRgun pointed at the thermostat house shows TRUTH.
If I ground the wire it pegs out hot, as it should. I swapped out the sender and it still reads low. (way are you doing this. the gauge is junk)
use a real instrument when working on cars. not that dash guage.
LOOK AT THAT GAUGE IT HAS NO NUMBERS (a toy it is) really its there to say ,gee why is the needle hitting H and off scale as the steam envelops the car.
no , its car that was abused, allowed to stake up failure after failure.
24 is a dead VSS no kick will ever run right with a bad VSS (cable snapped no less)
35 is a dead maf, good luck with that, see my maf page for full testing of that maf. new they are $1000 from suzuki.
the china clones are junk
and uses are hard find but best best.
if all these codes come back after a Dome fuse reset.
they are ALL real. the ECU does no lie ever about that.
they are catastrophic failure codes, all.
my joke
take the black tape off the CEL lamp and move it to the dash temp gauge. bingo your a mechanic.
in the olden days we used thermometer in the rad filler necks,etc, but not today!
you can use an IR GUN
or any good DMM with thermistor probe.
look ma, the truth and no burn fingers. like times of old.
id park, since MPG is like 15mpg
and fix the maf first. if it comes back. that part is the heart breaker. huh. I do hope you find one used and good.
i type MAF in my search box an get
http://www.fixkick.com/sensors/92-95...F-testing.html
Old 02-22-2013, 02:01 PM   #9 (permalink)
Glas1700's Avatar
Glas1700 is on a distinguished road
rockauto has Beck-Arnley MAF's for $235, but I don't know where they're made. They also carry remanufactured OEM MAF's for about the same price.
Byron
97 US Geo Tracker
2dr 5spd 4WD
225/75 Grabber AT2
Glas1700 is offline   Reply With Quote Quick reply to this message
Old 02-22-2013, 03:59 PM   #10 (permalink)
xxx
beck rebuilts. and good. ive used many. so is cardone, i have many links to Cardone,
just warning him ,its not Cheap. the $99 ones are junk.
http://www.rockauto.com/catalog/rafr...&parttype=5128
here is how an why limphome works.
is your speedo cable snapped, thats a $25 fix.
http://www.fixkick.com/ECU/LimpHome/failsafe.html
