Need help with '90 geo tracker lift kit - Suzuki Forums: Suzuki Forum Site
Old 01-20-2013, 09:06 PM   #1 (permalink)
jrobert102 is on a distinguished road
Default Need help with '90 geo tracker lift kit
I have a 1990 Geo Tracker and wanting to put a 2 inch body lift on it. I'm wanting to know how many and what mods do I have to do when I put one it. Will I have to change the rad hoses, brake lines, fuel lines? Need help.
jrobert102 is offline   Reply With Quote
Old 01-21-2013, 12:57 AM   #2 (permalink)
MUD_TRACKER is on a distinguished road
If your going only 2 inch I would recommend just some spring spacers. Got mine off eBay. Took about 2-3 hours to install. I got them on mine and I run 31 10.50 tires with no rub at full lock either direction. Only thing I had to mod was the rear shocks and used 91 crown Vic shocks. I like it. Just my opinion
Canadian cali 1990 Geo Tracker 5spd 4x4 8v 2"lift 31 9.50 15 Super Swamper tsl home made snorkel.
MUD_TRACKER is offline   Reply With Quote
Old 01-28-2013, 11:53 AM   #3 (permalink)
ox99racer is on a distinguished road
what was wrong with your shocks in the rear that you had to use the crown vics? im looking to do a small lift also and any info helps
ox99racer is offline   Reply With Quote
Old 01-28-2013, 12:37 PM   #4 (permalink)
hopper20's Avatar
hopper20 is on a distinguished road
with the lift it pulls the stock shocks out 2 inches which leaves you with 2 inches less of travel. Longer rear shocks give you that 2 inches back.
95 Geo Tracker LSI
1.6 L 16 valve
Pro Top Hardtop
235x75x15 Nexen Roadian MT's
Low Range Offroad 2 inch coil spacer lift (1.5" front and 2" Rear)
Low Range Offroad Strut Spacers
Low Range Offroad Rear Control Arm Spacer
Doetsch Tech Rear Shocks
hopper20 is offline   Reply With Quote
Old 01-28-2013, 05:55 PM   #5 (permalink)
loosenut is on a distinguished road
A coil spacer lift does not add travel, it just moves the suspension out effectively. I solved it with a spacer on the upper shock mount (rear) and used the original shocks. Rides really nice and at zero cost. The crown vic shocks will make your kick ride like a shopping cart. I am too old to ride in one of those
loosenut is offline   Reply With Quote
Old 01-28-2013, 05:59 PM   #6 (permalink)
Found the link...use locktite btw http://www.suzuki-forums.com/suzuki-...-2in-lift.html
Old 01-28-2013, 07:18 PM   #7 (permalink)
I used the Vic shocks that's what the guy told me to use. It help with farther travel when I off road the thing. Really depends on the reasons for lifting I guess
