ecm ?s - Suzuki Forums: Suzuki Forum Site
Old 01-16-2013, 05:16 AM   #1 (permalink)
deeznutts77's Avatar
Gallery: 4
Default ecm ?s
will changing ecm mess anything up to try and clear a misfire code?
had misfire on 2 so did plugs, wires, injector and cap now its on 3.
96 jx 5 speed 1.6 16v "cold" air and try y header, underdrive crank, kawasaki zx6 muzzy muffler, gm alt kit.
96 "sport" 3spd auto 1.6 16v 2dr geo tracker all stock
It might not b fast but it looks it!!!!
Old 01-16-2013, 05:22 AM   #2 (permalink)
Not quite sure I understand. If you have a misfire code, and then replacing the ECU with a compatible one for your car, the new ECU should also see the misfire, if the misfire is real. When you did the wires, does this mean you put in new ones, or just changed them around?? From your info, it would appear that whatever was done 'cleared' the misfire on 2, but now it appears on 3. ????
'61 NSU Quickly - 150mpg
Old 01-16-2013, 05:48 AM   #3 (permalink)
Gallery: 4
put diff ones on to c it it was the issue, wanted to c if the misfire is from ecm. if i take off slow it goes fine n drives at speed good but if i get into it it pops n studders.
Old 01-16-2013, 11:21 AM   #4 (permalink)
colonelhogan44's Avatar
colonelhogan44 is on a distinguished road
I highly doubt it's a ecu issue in a 1996 obd2 vehicle. Maybe the engine is running lean?
8V distributor O-rings - $5 shipped.
NEW MANUFACTURE: 89-94 soft top clips - $50/set shipped -- 3 tailgate and 2 side window, Lifetime Warranty - PM for details.
1993 Tracker 4x4, 2 door, 8v, 3 speed auto. 129.5k
1996 Tracker 4x4, 2 door, 16v, 3 speed auto. 98k
colonelhogan44 is offline   Reply With Quote
Old 01-16-2013, 12:03 PM   #5 (permalink)
razor02097's Avatar
Is the TPS good?
razor02097 is offline   Reply With Quote
Old 01-16-2013, 12:20 PM   #6 (permalink)
Gallery: 4
was gonna check that from other truck n go from there, like havin 2 96s so i can check parts b4 i buy.
Old 01-17-2013, 03:16 PM   #7 (permalink)
xxx
Originally Posted by deeznutts77 View Post
will changing ecm, mess anything up to try and clear a misfire code? (im not sure what that means)?
the ecu never lies about P0302 unless the timing belt is loose.
so chaining ecu should not fix that, if the #2 injector drivers were good.
which code?, P0302 or that and P0300s???,, need to know all codes thrown.
302'a can be.
loose tbelt.
low compression. on #2 , 170 is par.
bad spark plug ,wire or cap.
intake leak near #2 intake port (gasket)
weak injector #2 (swap to #1)
leaking injector #2 (swap with #1) did P0301 pop up?
bad ecu , #2 driver bad, moving injectors it stills #2 fails.
water leak to #2
far worse.........
there is a list of tests. easy to harder. its not unknown.
compression and tbelt check are tops.
do my sneak-a-peek test. is the crank bolt at 94 lbs per TSB?
lean,?
if the motor holds closed loop at idle
and at cruise, it's not lean. see long term trim LTFT , is it near 0 ? if it was lean it would show like +20 trim. or totally out of control.
i bet it dropping p0302 , cruising.
you do know there is a freeze frame page and can dump that and see exactly what motors was doing at the last posted DTC fail.
even speed, load, rpm, maf reading. etc.
xxx is offline   Reply With Quote
Old 01-17-2013, 04:04 PM   #8 (permalink)
Not much of a misfire, if he's cruising at 95mph, and blowing the hood off of his car.....
http://www.suzuki-forums.com/suzuki-...ode-today.html
Of course, Deez, you have a Kick and a Sport in your signature. So which car are you talking about??
Old 01-17-2013, 04:31 PM   #9 (permalink)
xxx
misfire is nothing.......
Old 01-18-2013, 06:41 AM   #10 (permalink)
Gallery: 4
it was 302 changed injector out to new one, then got 303. idles good have to take off slow n light on peddel, but goes good once up to 55+. t belt good, did some plug swapin and wire testin and regrounded the pump and gauge in tail light. after all that it went good for a lil bit then started it bs again. its in closed loop, sport in " cause it has a sport sticker on side not the real sport with 1.8 i wish!!
