911 please help! Drive axle problems 4x4 - Suzuki Forums: Suzuki Forum Site
Old 01-10-2013, 01:16 PM   #1 (permalink)
MedicTracker is on a distinguished road
Default 911 please help! Drive axle problems 4x4
Ok so I'm driving home one day and my driverside front wheel begins to start catching and making the car jerk to one side. I get out and grab the tire to shake it back and forth and the play it has is scary. So I got the tire off and the hub, everything was rusty as crap. Got to the flat lock washer and the Phillips screws are stuck. Anyone I mean anyone how do I get hose out? Also the bearing is just one press in bearing right?
1993 Geo Tracker; 1.6L I4, 5 speed, 4wd
MedicTracker is offline   Reply With Quote
Old 01-10-2013, 01:50 PM   #2 (permalink)
razor02097's Avatar
Yes. You need 5 things...
Patience
heat
penetrating oil
hammer
screwdriver
spray the penetrating oil on the whole thing. Soak the crap out of it. Wait a half hour and do it again. After another half hour heat the ring and screws with a heat gun until it is too hot to touch. Put the screwdriver to each screw and smack it with a hammer several times. Put one palm to the end of the screwdriver and put your weight into it. Twist with your other hand. If they do not loosen repeat the process.
You could use an impact driver with the right bit but be careful so you do not break the screws off. The penetrating oil, heat and impact will break loose all the rust and junk that is locking the threads in place.
razor02097 is offline   Reply With Quote
Old 01-10-2013, 02:37 PM   #3 (permalink)
ranger88den's Avatar
What razor said plus this link (click on colored links for more info):
swap out of front hub bearings
EDIT: After completion say "Thank you Jerry".
Old 01-13-2013, 04:38 PM   #4 (permalink)
Ok so I followed your advise now I can't get the lock nut off.... And I don't have the money to blow on the axle tool nor the time to wait for it. Any advise on its removal and its reinstallation?
Old 01-13-2013, 06:00 PM   #5 (permalink)
aquanaut20's Avatar
It is a necessary tool, either buy or mfg one, you will spend more on damaged parts trying without.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 385k
99 Tracker, 4dr, 4x4, 2L DOHC, auto 189k
Old 01-13-2013, 06:14 PM   #6 (permalink)
Ok.... Well then what do I need to install the bearing myself?
Old 01-13-2013, 07:00 PM   #7 (permalink)
aquanaut20's Avatar
A 12 ton press.... Philip
Old 01-13-2013, 07:06 PM   #8 (permalink)
razor02097's Avatar
Here...
To get the nut off without the tool you could use a cold chisel if you are careful but you will still need the tool to get the nut back on tight.
Old 01-25-2013, 07:37 PM   #9 (permalink)
Ok got the tool and put heat and all on that sucker and nothing. Which direction does it turn?
Old 01-25-2013, 07:50 PM   #10 (permalink)
razor02097's Avatar
To get it off it requires you to turn it counter clockwise.
I had to use a cold chisel on one of mine. I was afraid I would break my expensive tool.
