» Site Navigation
» Model Specific
» Buyers Guide
» Network Links
01-25-2013, 07:59 PM
#11 (permalink )
Gallery:
0
I'm using a air chisel and ain't getting no wear any advice?
1993 Geo Tracker; 1.6L I4, 5 speed, 4wd
01-25-2013, 08:21 PM
#12 (permalink )
Gallery:
0
A 1" cold chisel and a mini sledge will put a lot more force in a strike than an air hammer will.
You could try ATF and acetone. It's supposed to work as good or better than Kroil
01-27-2013, 11:34 PM
#13 (permalink )
Gallery:
0
finally got the sucker off with my air chisel and torch and PB blaster. And this is what I found. The Circlip was damaged pretty bad didn't know if it was repairable or where i could find another like it.
there was two other things I have no idea what they are may be someone could tell me.
Also can somone tell me from the attached pics how the 4x4 hub goes back together.
01-28-2013, 12:31 AM
#14 (permalink )
Gallery:
0
Use a beater smacker! (impact screwdriver) pawnshop, auto parts house
penetrating oil and heat, if this don't work you may have to cheisel the heads loose/or/ off or drill them out! good luck
01-28-2013, 12:33 AM
#15 (permalink )
Gallery:
0
if already got the lock washer off? got to get these part fixed or something does anyone know what these things are?
01-28-2013, 11:36 AM
#16 (permalink )
Gallery:
0
Can anyone help out I am so pressed for time trying to get this sucker back out on the road.
01-28-2013, 12:45 PM
#17 (permalink )
Gallery:
0
The two things you don't know what they are is actually a seal that seals the outer hub on the back side. (part 23 in below image)
The circlip looks in bad shape but you could reuse it in a pinch. Use a vise to get it straight and reinstall it.
To reassemble the hub refer to this from kickfix.com
swap out of front hub bearings
01-28-2013, 12:58 PM
#18 (permalink )
Gallery:
0
Great video on the locking hubs. Might as well service them, as well
'61 NSU Quickly - 150mpg
01-28-2013, 01:22 PM
#19 (permalink )
Gallery:
0
Originally Posted by
razor02097
Ok, the metal and rubber deal what do i do what that crap? I will get the circlip straighten out ASAP?
oh and bex thanks for the vid.
01-28-2013, 06:01 PM
#20 (permalink )
Gallery:
0
Ok snap ring is broke where do I find a new one?
Linear Mode
