2 Inch Wheel Spacer Completion - Suzuki Forums: Suzuki Forum Site
Old 01-03-2013, 11:35 AM   #1 (permalink)
Blackberie is on a distinguished road
Default 2 Inch Wheel Spacer Completion
Hi guys,
So I bought the 2 inch wheel spacers made of billet aluminum from ebay. The problem I ran into was that my studs were far too short for the spacers lug nuts that came with it.
I researched getting new studs, but that would have been a project. So for anyone putting wheel spacers on a sidekick I'd recommend going to brandsport.com
I found these specialized lug nuts that fit inside the wheel spacer with a tapered end.
12mm x 1.25 E/T Ultra Mag Seat Lug Nuts, Wheel Locks & Lock Sets
This was helpful for me to actually get some turns onto the stud and really get it down tight.. over 80 ft/lbs of torque
This is the after pictures I attached here. I didn't find anywhere on this forum that was too instructive on wheel spacers. The thread I commented on a while back was pretty vague. So I did plenty of research on wheel spacers so I hope this is helpful.
2 Inch Wheel Spacer Completion-2013-01-03_12-28-07_544.jpg   2 Inch Wheel Spacer Completion-2013-01-03_12-28-19_958.jpg   2 Inch Wheel Spacer Completion-2013-01-03_12-28-32_810.jpg
Blackberie is offline   Reply With Quote
Old 01-05-2013, 09:30 AM   #2 (permalink)
Peculiar1's Avatar
Gallery: 3
Peculiar1 is on a distinguished road
Looks good.
I'm to lazy anymore to want to wash vehicle every time I get into to mud Or I'd prob have a set on mine.
1994 Suzuki Sidekick 2dr 1.6, SOHC, 8valve, 4x4, Auto hubs, Manual trans, Mfg Cami
Peculiar1 is offline   Reply With Quote
Old 01-05-2013, 05:47 PM   #3 (permalink)
Cobb is on a distinguished road
Does it handle better? I started to get some spacer plates, but I couldnt find anything with the bolt pattern. I was on the fence about using the spacer washers you see at the auto stores like autozone, but ultimately decided with a larger tire.
Cobb is offline   Reply With Quote
Old 01-05-2013, 06:19 PM   #4 (permalink)
razor02097's Avatar
Don't use the spacer that spaces the tire further out on the studs. It is dangerous and put massive strain on the wheel studs. If you use a spacer use the kind like the OP got. The kind that bolt to the wheel hub and the wheel bolts to the spacer.
razor02097 is offline   Reply With Quote
Old 01-05-2013, 08:12 PM   #5 (permalink)
Glas1700 is on a distinguished road
I purchased a set of Spidertrax 1" wheel spacers. They're not cheap, but they fit perfectly and I'm happy with them. I didn't want the extra weight of steel wheels or the expense of new alloy wheels and since my OEM alloy wheels are in good shape, this was a reasonable compromise to get a wider track.
Byron
97 US Geo Tracker
2dr 5spd 4WD
Glas1700 is offline   Reply With Quote
Old 03-29-2013, 11:33 AM   #6 (permalink)
I finally got the 1 inch urthene coil spring spacers in so my rear tires dont rub the fenders. Its like a whole new car driving it. I get some funny things going over 60mph. I had my tires rebalanced and front end aligned before hand. For tires they went from weights on both sides to just the back side. I am thinking of asking them to rebalance them the old fashing way with weights on both sides.
Other than that its a much nicer ride, little to no roll in the corners like before.
95 sidekick ljx 4wd 5 speed 16v
235/75r15 yoko touring s
1.5 wheelspacers/curt hitch
3tech 5 degree cam advance
New shocks and HR lowering springs
Spare tire, roof rack delete
Old 04-04-2013, 11:14 AM   #7 (permalink)
So i decided to remove the wheel spacers. I had the 2" ones bolted up to the original stud. I was told by multiple people that although they do make the ride more stable, they increase the wear and stress on the studs and the bearings. I am going to save the spacers for when I am finally able to get extended studs. Just thought this might be helpful for someone who is thinking about it. I'm mildly regretting spending the money originally, but I figure it's better to just suck it up and live with it. We all have old cars so we should just focus on keeping them safe/running. My 2 cents lol
Old 04-16-2013, 03:19 PM   #8 (permalink)
zeroluck's Avatar
zeroluck is on a distinguished road
Garage
I just bought some new wheels from 4wheelparts.com. I got pro comp 52 series rock crawlers with a 2.5" backspacing This should make them stick out quite a bit to fit with my fender flares. I called in because I wanted normal shaped acorn chrome lugs and they didn't have squat on their site. After calling in, he found me $1 chrome lugs and $3 black center caps that aren't listed on the site. Here is the invoice:
1994 US 1.6L 8v 2WD 2DR 5SPD Ragtop
zeroluck is offline   Reply With Quote
