new sidekick owner 4wd question - Suzuki Forums: Suzuki Forum Site
Old 12-21-2012, 11:51 PM   #1 (permalink)
fbodylvr is on a distinguished road
Default new sidekick owner 4wd question
I just purchaced my 97 sidekick for 700 bucks with 163000 miles. My intent was to use it as a winter beater thats great in the snow. We just got the first snow of the year yesterday and at first it seemed like the 4wd was working fantastic and was great fun. However after the snow got packed down i ended up in a ditch. I thought it would be fairly easy to get out but in 4wd only the rear wheels were spinning. It is my first 4wd vehicle so im not an expert on how they work. The 4wd seems to be working fine under normal driving and even when correcting oversteer. Is this normal for these cars or do i have a problem.
1997 suzuki sidekick 4 door 4wd
1987 GMC suburban 350ci 2wd
fbodylvr is offline   Reply With Quote
Old 12-22-2012, 12:06 AM   #2 (permalink)
colonelhogan44's Avatar
colonelhogan44 is on a distinguished road
Did you lock the hubs?
8V distributor O-rings - $5 shipped.
NEW MANUFACTURE: 89-94 soft top clips - $50/set shipped -- 3 tailgate and 2 side window, Lifetime Warranty - PM for details.
1993 Tracker 4x4, 2 door, 8v, 3 speed auto. 129.5k
1996 Tracker 4x4, 2 door, 16v, 3 speed auto. 98k
colonelhogan44 is offline   Reply With Quote
Old 12-22-2012, 12:16 AM   #3 (permalink)
Not manual hubs
Old 12-22-2012, 01:02 AM   #4 (permalink)
Then I'd say your auto hubs are highly suspect.
Old 12-22-2012, 02:33 AM   #5 (permalink)
How difficult is it to convert to manual hubs
Old 12-22-2012, 05:14 AM   #6 (permalink)
Not difficult at all. Pull off the auto hubs, put on the manuals. Auto hubs (IMHO) are a PIA, as you never really know if they are locked, and if you change direction (like trying to rock your way out of a stuck situation) they can lock/unlock, etc. The 1997 Tracker has a strange wavy washer in the hub application (but not the Sidekick AFAIK) so any year other than that will be a direct swap. The manual hubs are servicable/repairable too, while the auto hubs really aren't. Plenty of info on how to service the manual hubs on the forum.
'61 NSU Quickly - 150mpg
Old 12-22-2012, 09:59 AM   #7 (permalink)
xxx
buy them at any store
there are many after market brands.
see my 4wd test page.
shows who to test 5 ways.
on jack stands is best way.
got stands?
and with your stock axles
the tire with he least traction will get all torque. (a counter logical fact)
so is not really 4wd (it is on dirt , but not with one wheel off ground)
LSD axles solve that .
and in a ditch with front hubs actually locked
apply the hand brake about 20% and this makes the loose wheels
trans fire power to the traction side.
practice with ice on one side. see....... see it work?
do not use 4wd on hard pavement.
only on grass,dirt,sand, clay,, or ice and snow.
never just wet or dry pavement
when I say 4wd, that means the looking hubs are in fact locked
all other ways are not 4wd, (the knob is not proof of 4wd at all)
some like to play games with words, im talking mechanics....
reality!
xxx is offline   Reply With Quote
Old 12-22-2012, 07:29 PM   #8 (permalink)
While in 2wd take the caps off the hubs and observe the position of the splines inside/take a picture. At the same time make a mark on your front drive shaft.
Engage 4wd and drive forward a couple of feet and if the position hasn't changed then the hubs are probably stuck open. You may also hear a click if they engage.
But to double check, recheck the mark on your front shaft and if it has moved then 100% hubs are stuck open. If it hasn't moved then you are looking at other problems.
Japanese Escudo, '93, 4 door, 16v, 4 spd Auto trans, 4WD, Auto locking hubs
Scudo is offline   Reply With Quote
Old 12-22-2012, 07:47 PM   #9 (permalink)
Lots of great info. Thanks to everyone for the advice. Im definately going to look into manual hubs asap. One more question. My car is auto and at 65mph the rpms are almost 4 grand. It just seems alot higher than it should be. Is this normal?
Old 12-22-2012, 09:27 PM   #10 (permalink)
How almost is almost?
3 or 4 speed auto?
