Which lift is easiest? - Suzuki Forums: Suzuki Forum Site
Old 12-06-2012, 10:48 PM   #1 (permalink)
pvtcook is on a distinguished road
Default Which lift is easiest?
Would a 2" spacer lift or 2" body lift be easiest? Thanks
pvtcook is offline   Reply With Quote
Old 12-06-2012, 11:30 PM   #2 (permalink)
The Goat's Avatar
The Goat is on a distinguished road
With two jacks, some Jack stands, and handtools... neither is hard at all.
If I had to choose... the body lift can sometimes not line up exactly right and can be a pain, but even still pretty easy.
1995 4DR Sidekick 16v w/4spd Auto J-Vin 187k
4.5in Low Range Offroad combo Lift
Calmini Front Brace
Sway bar delete
33x12.5x15 Duratracs
2.25 Piping with magnaflow exhaust and cat
Monstalined interior
Bumpers, lights, Armadillo Bedlined top, navigation...stuff.
So much to do!
The Goat is offline   Reply With Quote
Old 12-07-2012, 12:06 AM   #3 (permalink)
myvmax1 is on a distinguished road
Before you settle one way or the other check your body mounts. I've seen several (mine included) that were rusted to the point where I would not install a body lift.
92 Tracker 4x4 8V TBI 5 speed on 235/75/15
No cat, full 2in pipes through dynomax turbo muff.
Manual steering, Manual trans, Manual hubs... Hell, as long as its not kick-start I'm good.
myvmax1 is offline   Reply With Quote
Old 12-07-2012, 01:36 AM   #4 (permalink)
devilzook is on a distinguished road
body lift is not so good over 1" as i was told..spring over kit is best..i did it myself on my bro in law, of course they are there too but only me doing the work, its my first time too...one thing you mite not be able to do is weld the perch i believe its called onto the axle housing...also 1" will give barely enough space for future swap a 1.6L
devilzook is offline   Reply With Quote
Old 12-07-2012, 06:43 AM   #5 (permalink)
Did they also tell you why a body lift over 1" is not so good?
I suspect you're a little confused as to what vehicle we're discussing - you seem to be thinking leaf sprung Samurai (you mention a spring over and a future swap to a 1.6), whilst the OP does not tell us what vehicle, he is posting in the 89~98 Sidekick forum, so presumably that's the vehicle he's asking about.
Anyway - I would challenge your theory that a spring over is easiest - in addition to the welding & fabrication, you're changing the suspension geometry to such an extent that you're going to have to address drive line angles, spring wrap, front end castor angle, and fit some sort of high steer kit to get the tie-rods back to a reasonable angle.
A combination of body & spring lift would be simpler than spring over.
To get back on topic however - for the coil sprung vehicle - assuming the idea is to get increased clearance for a larger tire, a body lift will probably be simpler, provided you don't have the rust issues mentioned in a
previous response.
Spacers will give you the clearance but will force you to address the suspension geometry changes created by the lift - you're going to have to address shock/strut travel at both ends, and camber change on the front wheels.
93 - 1.3 Suzuki Swift GLX
98 - 2.0 Suzuki Grand Vitara
fordem is online now   Reply With Quote
Old 12-07-2012, 07:42 AM   #6 (permalink)
Sorry guys thought my vehicle type was in my signature. It's a 96 tracker. Thanks
Old 12-07-2012, 08:37 AM   #7 (permalink)
Dayton86's Avatar
Dayton86 is on a distinguished road
Wow Corinth is not to far from me. Used to pass through there a lot. Anyways what is your overall plan for the tracker? We maybe able to help point you in the right direction if we know that. Good luck on it and nice to see a local guy on here.
1994 Sidekick JX 1.6-8v-5speed-4x4-2dr-FED Emission 206k miles and counting!
Ted Nugent, "Conversely, gun control a la Ted Nugent is putting the second shot through the same hole as the first shot, where innocent lives are saved and recidivistic maggots come to a screeching halt, felled by the lovely ballet of good over evil we call the "Double Tap Center Mass Boogie." Learn it, know it, love it, shoot it. Good guys should live, bad guys, not so much."
Dayton86 is online now   Reply With Quote
Old 12-07-2012, 10:29 AM   #8 (permalink)
Hey man thanks. Where are you located? I'm not planning on doing any off roading I just like the way the trackers look w a lift and tires. The guy I bought it from also had a brand new set of BFG MT KM2 tires. I bought them but They are 215-75-15 though and I think I would rather have some 235's. I don't know if a 2"lift would look right w that size tire. I thought about using the 215's w a 1" lift but I think I would like more than a 1" lift. I just didn't know which lift would be easiest. The tracker isn't from up north but yesterday I had to put a front wheel bearing on and I had to heat the two brake caliper bolts to get them out. And when I started taking the six bolts out of the locking hub two of those twisted off. Luckily there was enough sticking out that I could get some vise grips on so I heated the hub until red w my torch and got them out. My point being that could mean that the body bolts would be tough to remove!
96 and 98 2dr 4wd geo tracker
Old 12-08-2012, 07:27 AM   #9 (permalink)
Dayton86's Avatar
Desoto county. Northwest corner MS. Just south of memphis. Some people have gotten away with 235 and no lift. But I was not that lucky. I have one inch coil spacers on mine and rolled the lip inside the rear wheel well and have no problems now. My wheel width and offset are kinda wide so that did affect it somewhat. It almost looks like it should have came factory like this.
Old 12-08-2012, 05:52 PM   #10 (permalink)
yes you are correct about all the steering geometry n spacers...i was thinking of samurai as i was reading it sorry..but just to lift is what i meant..to make it lift and drivable everything you said is right on plus adding extended brake lines
