looking for a few parts... - Suzuki Forums: Suzuki Forum Site
Old 11-20-2012, 09:33 AM   #1 (permalink)
road_tripper is on a distinguished road
Default looking for a few parts...
I am ending up doing a bit of part replacing on the 22-year-old parts that are all wearing out. Are there any brands that are worth the extra money? (I've looked at the kick-fix site (THANKS!!) for answers to most of my questions).
Example:
water pump: AC delco 'cast iron impeller' better than Gates?
I'm also looking for the gasket/seal that goes between the throttle body and the intake runner (sits around the fuel injector). picture is attached. Can't seem to find it anywhere...
Car details in sig.
1991 Geo Tracker, 4x4, 2 door tin top, CAMI, A/C, 3-spd Hydramatic, RWAL brakes
road_tripper is offline   Reply With Quote
Old 11-20-2012, 09:56 AM   #2 (permalink)
ranger88den's Avatar
I purchased a throttle body rebuild kit from Rockauto that included everything I needed for my '92 Tracker 8v.
Old 11-20-2012, 10:11 AM   #3 (permalink)
I'm guessing I'm suppose to use the one pictured below? seemed much thinner than the round one currently installed...
Old 11-20-2012, 12:12 PM   #4 (permalink)
xxx
your old one evaporate>? even the stuck on parts are clear to see?
btw A/T and M/T are different.
my hard to by parts page
has that (see my annotted link there. IDs each part
hard to find parts, some are very hard !
xxx is offline   Reply With Quote
Old 11-20-2012, 12:38 PM   #5 (permalink)
I thought I mentioned I have an auto transmission...
The old gasket is still on the top of the throttle body. since it's probably 20+ years old and brittle, i'd like to replace it.
the throttle body rebuild kit (annotated picture from your site included) does not show it or include the gasket/seal I originally asked about. (I have the kit in hand).
I guess you could have noticed that the gasket I'm looking for is mentioned nowhere in your annotated parts list for the gasket set (shown below).
Maybe my eyes are going bad and I just can't see it?
Old 11-20-2012, 01:47 PM   #6 (permalink)
xxx
im sorry i can not decode that.... not a problem the physical world is best done in graphics....
the TB base gaskets are in that kit.
so you must mean the injector 0-rings..... below has them. and are hard to find.
between tb and intake
no , ok
injector seals , on is viton fuel side other is vacuum cushion seal.
same page.
and takes you here
injector seal kits
i show the 3 steps so you can see, all the other hard finds.
Old 11-20-2012, 02:06 PM   #7 (permalink)
xxx
those are injector o-rings, you never said inside the TB.?
injector seal kits
very hard to find,
suzuki dont sell them not in 5 years.
GB reman inc ,did
pn 8-011
ive tried to find them
but my injector service cleaned mine for $19 and added 2 seals.
there are 3 companies that stopped. making the kit
GP was the last.
i begged Rockauto to stock them
SEEMS THEY STILL, amazing....
RockAuto Parts Catalog
oriellys
shows BWD 27478
says it fits. so does BWD ECAT.
Old 11-20-2012, 02:25 PM   #8 (permalink)
below is a picture of the gasket/seal (in green) I'm looking for.
unmodified version is in first post. (apologies to anyone who's color blind)
Old 11-20-2012, 02:31 PM   #9 (permalink)
xxx
NEW or rebuilt?, (2 vastly different answers)
water pump. (as you know there are many parts in the slot)
china (made by Som Ting Wong (junk) any thing with china bearing is junk.
(bearings with same name.)
Japan made (prime)
beck
acdelco
gates all these are good. cept , WONG
look on rockauto.com see the cheap $17 one , avoid it like the plague.
in my local store
they drop rebuilts on the counter
its sand blasted so bad, (looked like grade 10 sand (from the moon)
and destroyed the thread in the mounts. (tbelt idler)
and had chain crap bearings (no name)
buy new.
Old 11-20-2012, 02:41 PM   #10 (permalink)
xxx
my god. that just a air tube gasket, make one.?
rock dont have it and never seen one ever ask for one, its so simple.
if you have the old one take it to a auto store and ask for a match up.
not on a week end they be too busy,
some will make the attempt.
did you look in the Felpro ecat? oops they dont make it.... i always buy felpro first...
ok now suzuki
13855-61a00
$2.54
Suzuki Parts - Suzuki Parts | OEM Suzuki Parts | Genuine Suzuki Parts
