My X 90 throwing code 1410 ?? - Suzuki Forums: Suzuki Forum Site
Old 11-13-2012, 08:46 PM   #1 (permalink)
GASSITT@aol.com is on a distinguished road
Default My X 90 throwing code 1410 ??
For a couple years now my Suzuki X90 has been putting the idiot light on and throwing code 1410 any idea what that might be , Thanks , all help appreciated
GASSITT
GASSITT@aol.com is offline   Reply With Quote
Old 11-14-2012, 10:59 AM   #2 (permalink)
xxx
loose gas cap,? or someone put a non vacuum breaking gas cap on your car
wrong cap.???
obd2 , 96-98 x90
click my 96 page, here.
and behold' P1 codes are suz only codes.
fuel tank pressure fail, EVAP 2 fail.
http://kickfix.ac-vw.com/CEL/96_ALL_..._all_dtcs1.pdf
the 96 full information on that is here.
at ackfaq.
here is the direct link
chapter 1
Ack's FAQ: Your 4X4 Portal To All Things Suzuki/Geo
and
chapter 2 (fun, it is complex.
xxx is offline   Reply With Quote
Old 11-14-2012, 12:32 PM   #3 (permalink)
Evap/fuel tank pressure control system malfunction. Easiest thing to check is to make sure you have the proper gas cap on the car. Some info and links for you here for the evap canister system, in case the gas cap is not the culprit. By the way, the check engine light is not an idiot light. When the CEL goes on, you should attend to it, as the computer is trying to communicate with you.
'61 NSU Quickly - 150mpg
Old 11-15-2012, 10:40 AM   #4 (permalink)
xxx
96/97 is a cusp year.
EVAP 1 to EVAP 2
the under hood sticker shows which it is. (open hood , look uP
that vacuum MAP seem, and the EVAP words....there...
EVAP 2 is tricky, (yes, put on a new gas cap,) or was it loose like 9 out of 10 fails. for EVAP.
vasts number of tests on EVAP 2
tighten cap,, new cap drive for a week and report
you never said the year.
and evolved 4 times. 96-98
and fed is not like Calif.
so the under hood sticker (open hood, look up) see vacuum map
see words calif, anywhere on that white sticker, with word compliance ?
the be the Calif versin
in 98 changes again.
so not posting year, kills all good responses
the rear of car at tank
the new VSV valve was in 96 calif models, and 97 and in the Fed 98 model , tricky , huh?
new vsv. new ecu, and new tests procedures in the books.
