fuel injection problem - Suzuki Forums: Suzuki Forum Site
Old 09-10-2012, 01:46 PM   #1 (permalink)
trackerrob is on a distinguished road
Default fuel injection problem
hi all , been lurking on the site for a year or so now need help, have 1995 tracker 16 valve, 5 speed. tracker needed valve job had it done, got it all together and truck would not run , has spark , fuel pump works, checked the fuel injecters and only 2 have pulse to them, sent ecm out tested good, same problem, all 4 injecters are new, please help, you guys know your stuff!
trackerrob is offline   Reply With Quote Quick reply to this message
Old 09-10-2012, 02:17 PM   #2 (permalink)
aquanaut20's Avatar
You need to check the pulse exiting the ECU then check the wire loom for disconnected/poor connectors.....
If loom is good you should have B+ at the injector and no ground, pulse is via ground/ECU... DO NOT apply raw B+ to injectors....... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
99 Tracker, 4dr, 4x4, 2L DOHC, auto 200k
Old 09-10-2012, 04:44 PM   #3 (permalink)
phillp thanks for your reply, how would i find where on the ecm to check for pulse? is it shown in the fsm?
Old 09-10-2012, 05:42 PM   #4 (permalink)
Section Moderator
Do a noid test on each injector, which will test for the electrical pulse at each injector (the noid light will pulse). You are testing at the injector connector.
Noid Light How to Use a Noid Light
And to repeat what Aqua said: do not hotwire the injector to try to test it.
'61 NSU Quickly - 150mpg
Old 09-10-2012, 08:07 PM   #5 (permalink)
GumbyCT is on a distinguished road
You need to check how you have the timing setup on this.
96 Geo Metro 84 k mi 3cyl 5sp Lsi
01 Chevy Tracker 4D, 2.5L auto trans, A/C, ps, 125k, mi. auto locking hubs
Under Repair
95 Tracker 2D Conv. 16v VIN#6 171k mi. 5sp A/C ps
96 Sidekick Sport 4D 1.8L, auto AC 114k mi.
GumbyCT is offline   Reply With Quote Quick reply to this message
