Question about 1" coil spring spacer lift - Suzuki Forums: Suzuki Forum Site
Old 08-29-2012, 01:02 AM   #1 (permalink)
Blackberie is on a distinguished road
Default Question about 1" coil spring spacer lift
Got a 96 kick..want to put on the 1 inch spacers but i'm concerned about tire tread, alignment and the brake lines not reaching. Can I put the 1" spacers on without worrying about all that jazz? I can do average stuff but nothing really major
Blackberie is offline   Reply With Quote
Old 08-29-2012, 01:44 AM   #2 (permalink)
littlebigman is on a distinguished road
Garage
Is this front and rear?
I have seen people run 2" spacers no worries so I think your fine there...
93 Sidekick 2DR 4x4 5speed 1.6L 8V
Homebrew intake
Thrush turbo muffler-sounds sick!
Bored out cat 7/8"
15x7 83 ford mag alloy's coated black
Red LED interior lights
2-4" wide rectangle off road lights
Front and rear bumper cover's gone
To come:
1" spacers under front springs
235x75R15 Hercules Trail Grabber's
KYB struts/shocks
Lowrange RV cam
Lowrange headers
LSD rear end
littlebigman is offline   Reply With Quote
Old 08-29-2012, 05:54 AM   #3 (permalink)
Dayton86's Avatar
Dayton86 is on a distinguished road
Anytime you break down the front suspension you are supposed to get an alignment. With that being said I put one inch spacers on mine almost 25,000 miles ago and have yet to get mine aligned without any ill effects.
Ymmv.
1994 Sidekick JX 1.6-8v-5speed-4x4-2dr-FED Emission 206k miles and counting!
Ted Nugent, "Conversely, gun control a la Ted Nugent is putting the second shot through the same hole as the first shot, where innocent lives are saved and recidivistic maggots come to a screeching halt, felled by the lovely ballet of good over evil we call the "Double Tap Center Mass Boogie." Learn it, know it, love it, shoot it. Good guys should live, bad guys, not so much."
Dayton86 is offline   Reply With Quote
Old 08-29-2012, 11:48 AM   #4 (permalink)
Yeah this is front and rear. I appreciate it guys thank you. I'm gonna try out the 1" and see how it goes.
Old 08-29-2012, 12:11 PM   #5 (permalink)
Ymmv.
I'd say it depends on what you do when you break it down - I've pulled spindles so I could press out the bearings, I've changed struts, I've changed bushings - stuff that does not change any of the geometry really doesn't need re-alignment.
A spring or spacer lift on the other hand, that changes the ride height, which changes the angle that the control arm sits at, will affect the geometry and usually makes the camber more positive - that might need an alignment.
Please note however, stock, the only available adjustment is the toe, so if you do need to correct the camber as a result of a lift, you'll need a set of camber bolts to do it.
93 - 1.3 Suzuki Swift GLX
98 - 2.0 Suzuki Grand Vitara
Old 08-30-2012, 05:27 AM   #6 (permalink)
Ira
Ira is on a distinguished road
When I did my 2" lift years ago (well, my MECHANIC did it), everything reached with no problem.
Upon completion, he eyeballed it and said the alignment looked right on. A few weeks later, I brought it to an alignment specialist elsewhere and the guy looked at it and said it was already pretty damn right, and said I didn't need it.
Years later, tire wire has still been even, and rides fine.
95 2dr Geo Tracker, 2wd, 1.6, 8v, 3-spd auto, 2" Spacers Lift...and 2" still uninstalled wheel spacers that mock me from their box sitting on my rear bench.
Ira is offline   Reply With Quote
Old 11-11-2012, 11:02 PM   #7 (permalink)
Hey guys I made this thread before about the spacers. I did not get around installing them yet but I ordered 4 more 1 inch spacers..so I am going to put 2 1 inch spacers all around. My question is do I put one on top and bottom of spring? Not entirely sure the best way to install them with least amount of work.
Also should I drop the control arm or use a spring compressor?
Im an amateur at this stuff so any and all advice I would appreciate. Thanks guys.
Old 11-12-2012, 04:27 AM   #8 (permalink)
Rhinoman's Avatar
What sort of spacers are they? stacking spacers may not be advisable. You will need camber adjustment bolts, longer shocks and strut spacers. The brake lines should be OK with just a 2" lift and the rear upper arm ball joint should also be OK if you don't go longer than +2" on the rear shocks. The front spacers should be thinner than the rear spacers because of the position of the springs on the wishbone, two 2" thick spacers would be too much.
It easiest to drop the control arm, I couldn't actually get a coil spring compressor to fit.
http://www.rhinopower.org
2000 1.6 8V Vitara, Calmini 3+3, 33 MTs, 5:83R&Ps, remapped ECU
2000 1.6 16V Baleno GS, stock
1986 SJ413K pick-up with G16B conversion
1984 SJ410 tube buggy
Old 11-12-2012, 04:40 AM   #9 (permalink)
blaze10 is on a distinguished road
Yeah I don't know how stacking two one inch spacers would go.
blaze10 is offline   Reply With Quote
Old 11-12-2012, 11:43 AM   #10 (permalink)
Hey guys these are the spacers I bought from jcwhitney.
Mr Gasket SUPER RUBBER SPRING SPACER - JCWhitney
