need help with cam install, timing and balancer removal - Suzuki Forums: Suzuki Forum Site
Old 04-20-2012, 06:25 AM   #1 (permalink)
kryptonite is on a distinguished road
Default need help with cam install, timing and balancer removal
HI all.My 93 Vitara, G16B engine has done a head gasket. I've replaced the gasket and put the head back on, now i have a problem with the camshaft. I could not get it back in so i backed of the rockers (i think thats what there called in these engines) and now im worried they won't be set to the right heights on the valve springs as I noticed they're adjustable. Also I need to get the harmonic balancer off but it's not budging. Do those 5 bolts need to be unbolted and if so whats size are they.10mm seems to fit but there not undoing. Once I have the balancer off Im also lost for how to set the timing right and the correct torque specs. Sorry for all the questions.My repair manual is on the way but I need the car on the rd yesterday.
kryptonite is offline   Reply With Quote Quick reply to this message
Old 04-20-2012, 08:21 AM   #2 (permalink)
Section Moderator
For the harmonic balancer, I believe that the bolts are 8mm - there are 6 of them, perhaps that's your problem?? Normally after the 6 bolts are removed, you just tap on the balancer and it falls off.
If you search the forum, you can get detailed info on how to do the timing belt. First however, you should remove the crank pulley and check the keyway to make sure that it isn't sheared. The crank pulley bolt must be torqued to 94 ft/lbs. Simply put, the crank key is at 12:00. The cam key is at 6:00. You use the E marks on the cam pulley (there are often I marks as well, as the pulley is also used in the DOHC engine). With the new belt on, the right side of the belt (as you are standing in front of the car) should be tight - all looseness on the other side of the belt. Then when you release the idler pulley, the spring on it will set the right tension. The t-belt is set to cylinder #4 firing.
For the valve lash, spec for all is .006 inches. When looking at the car from the front, you have 4 sets of 2 valves on the right and on the left. You adjust the first and second set on the left (as you are standing in the front, looking at the car) and the first and third on the right first (cylinder #1 firing). Then rotate the crankshaft 360 degrees clockwise till you are at top dead center again (cylinder #4 firing) then set the third and 4th set on the left, and the second and fourth set on the right to .006.
I'm sure others will come in to fill the gaps, or search the forum or ask for other info you need. Good luck.
'61 NSU Quickly - 150mpg
Old 04-20-2012, 08:43 AM   #3 (permalink)
ranger88den's Avatar
I have also found the crank pulley fastened with 5 socket head bolts but don't remember what metric allen head size. If applicable, I can find out.
Old 04-20-2012, 09:25 AM   #4 (permalink)
Section Moderator
Yes, sorry, the accessory drive pulley on the outside has just 5 bolts, then the inner pulley has the one large bolt.
Old 04-20-2012, 05:31 PM   #5 (permalink)
Sad but true story: When I first tried to work on my first Geo at 17, I tried to rip the bottom crank bolt out to remove the harmonic balancer, that thing would not budge even with an older impact... then I felt down and looked with flashlight, felt really dumb after that.
below are documents to assist. credit to jerry.
could not attach the other so here it is : 8vsettiming.pdf download - 2shared
95' 2dr Track 4x2 3-speed auto, 8v, 1.6L
93' 2dr Track 4x4 5-speed manual, 8v, 1.6
For quicker assistance please post the YEAR, MAKE, MODEL, ENGINE, TRANS, MILEAGE.
CodyJ is offline   Reply With Quote Quick reply to this message
Old 04-20-2012, 06:49 PM   #6 (permalink)
Section Moderator
The G16B may be the 16v engine??
Old 04-20-2012, 11:59 PM   #7 (permalink)
Ok I can't seem to find the marks on the cogs. Am I looking for an actual E. I've found what looks like an arrow and a 0 is that what I line up. Also what toque setting for the cam cap bolts
Old 04-21-2012, 12:02 AM   #8 (permalink)
you have 8v or 16v motor?
8v (stupid imageshack... cant direct link anymore)
http://imageshack.us/f/4/donebelt1.jpg/
16v
Old 04-21-2012, 12:16 AM   #9 (permalink)
Ok found the marks on te top cog. So they point straight down and te ones in the bottom cog point straight up
Old 04-21-2012, 12:36 AM   #10 (permalink)
missing the question of 8v or 16v. i cannot give you answer without you answering that.
