starter upper bolt-size length? - Suzuki Forums: Suzuki Forum Site
Old 11-08-2011, 11:48 PM   #1 (permalink)
trackerER is on a distinguished road
Default starter upper bolt-size length?
Hi guys,
I just finished rebuilding my tranny and putting it back on now. However, it seems I lost the starter top bolt.
Do you now the size, thread and length of it?
Is it just a bolt that threads in or a bolt and a nut?
I think it's a bolt and a nut but I'm not positive?
All I remember is that I removed it using a 12mm box wrench.
Thanks,
1990 Geo Tracker LSI, 1.6L, 8v, manual tranny, 4x4, 2dr, soft top.
trackerER is offline   Reply With Quote Quick reply to this message
Old 11-09-2011, 02:15 AM   #2 (permalink)
OK. I just did a little search and I think the bolt is supposed to be JIS 8mm bolt, 1.25 pitch and 12.25mm head. I can't remember the length though.
Also, I'm still not sure whether it was a bolt or a bolt-and-nut.
Thanks,
Old 11-09-2011, 08:34 AM   #3 (permalink)
Banned
fix-kick is on a distinguished road
the bell housing is threaded for that bolt.
so there is no nut.
it be same diameter as lower bolt (measure it) (got caliper, no , why not?)
and has same ISO thread pitch, measure it.
that gets you to one mystery length.
you should buy a metric pitch gage for $1 and add it to your shop tool box.
and a cheap caliper so you can measure any bolt.
now that you know the diameter and pitch, all that remains is length
i take a coffee swizzle stick, jam it in the hole.
i then press thumb into stick at flange.
i extract the swizzle , lay it against, my ruler. all X inches ,the
add starter flange thickness Y
X + Y = Z
i multiply Z times ,25.5 and bingo , metric. OMG i measured length.
i then subract 2-3mm from my reading and buy that bolt.
if really flush with cash(LOL) I buy 2sizes, above calc. and next size down.
there, taught you how to fish, no fish to give
btw, the suzuki docs dont show sizes.
and does sell the bolt. i have pn. but im sure you dont want it.
fix-kick is offline   Reply With Quote Quick reply to this message
Old 11-09-2011, 08:38 AM   #4 (permalink)
Banned
caliper 1a
measure diameter
.314" about.
(.314 x 25.4 = 8mm
now you can discover the size of all ISO metric bolts. (use a screw that fits the unknown nut to find nut sizes )
pitch is even easier. pitch is even easier.
shop skills.
most parts are 6,8,10,12mm
some are fine pitch.
the pitch gauge , solves the hard part. ( SAE bolts are much more easy, TPS, threads per inch is so easy to measure)
and length is childs play. measure it.
