Clutch and fly wheel recomendation - Page 3 - Suzuki Forums: Suzuki Forum Site
Old 11-21-2012, 04:48 AM   #21 (permalink)
Gega_Met is on a distinguished road
Scudo
I decided to go with Stage 1 clutch
PPC Stage 1 Clutch Kit Geo Chevy Tracker Suzuki x 90 Sidekick 1 6L 1 8L I4 | eBay
as I'm planing to make engine and transmission swap next spring it will be enough.
Gega_Met is offline   Reply With Quote
Old 11-21-2012, 07:42 AM   #22 (permalink)
razor02097's Avatar
A good plan would be to swap in V8....and invest in many rear tires.
Being serious though the stock component clutch should serve the purpose especially if you aren't going to greatly increase horsepower somehow. Hopefully the stage 1 clutch is more kind than a stage 1 clutch for a 4th gen Camaro... If not and you drive it on the street much you will want to invest in a good strong starter because you will be stalling a lot.
razor02097 is offline   Reply With Quote
Old 11-21-2012, 07:59 AM   #23 (permalink)
razor02097
Why starter is important for clutch? As I have read Stage 1 is like OEM but with better material to withstand slipping and driving 32 tires instead of 27. Stage 1 doesn't affect effort on the clutch pedal while Stage 2 and 3 are heavier and need to be changed flywheel with better material.
I plan to swap J20A with its automatic transmission for off-roading, not for a drag car.
Old 11-21-2012, 08:13 AM   #24 (permalink)
razor02097's Avatar
"performance" clutches tend to grab a lot more aggressively than OEM clutches do. It's just the nature of the beast. The starter is for starting the engine after stalling.
Old 11-21-2012, 08:35 AM   #25 (permalink)
razor02097
stage 1 can't be called "performance" - it's little bit strong- as it was explained where I have read it. Let's wait, at least someone has to try it
