Automatic Transmission Fluid Capacity - Suzuki Forums: Suzuki Forum Site
Old 05-16-2011, 08:40 PM   #1 (permalink)
chris7584 is on a distinguished road
Default Automatic Transmission Fluid Capacity
Hello,
I have a new to me 1994 Suzuki Sidekick 4dr automatic 4x4. I just dropped the trans pan and changed the filter but I am a little confused as the manual and the auto parts store told me around 2.6 quarts to fill. However I am on 4 quarts already and just barely on the dipstick... whats the deal. Also I noticed that there is a small vacuum hose in the engine compartment leading from the front diff and not attached to anything on the other end... what is this?
Thank you for any replies,
Chris
1994 Suzuki Sidekick 4dr Auto
chris7584 is offline   Reply With Quote Quick reply to this message
Old 05-16-2011, 09:03 PM   #2 (permalink)
loosenut is on a distinguished road
That small hose coming off the front diff is likely your vent. 4 quarts is in the right neighborhood. 2.6 sounds skinny
loosenut is offline   Reply With Quote Quick reply to this message
Old 05-16-2011, 09:06 PM   #3 (permalink)
That vent tube should run from the diff up into the engine bay near front of rocker cover and would have had a cap on it. This vent allows the diff to get warm and allow the air in the pumpkin to ebb and flow with the heat changes.
Old 05-16-2011, 10:16 PM   #4 (permalink)
tpatrickd1 is on a distinguished road
I want to tell you a story about changing tranny fluid in my geo trackers. I would once a year have my mechanic change my tranny fluid in my trackers. He would take the pan off and change the filter- about 3 qts. Well I found out when I took it to real tranny shop and hade them do a tranny service where they actually drain the torque converter and do it right the tranny holds approximately 10 qts. Don`t believe me? Ask the experts.
tpatrickd1 is offline   Reply With Quote Quick reply to this message
Old 05-17-2011, 03:58 AM   #5 (permalink)
Section Moderator
10 quarts?? You must have a leak somewhere - are you sure it isn't dripping out on the floor??
If you are just draining and refilling the auto tranny (specs for 3 speed), it takes 6 pints (2.8 liters) of tranny fluid. If you are doing an overhaul, it takes 9.7 pints (4.6 liters).
'61 NSU Quickly - 150mpg
Old 05-17-2011, 11:36 AM   #6 (permalink)
I called my tranny shop this morning to ask him again about the tranny capacity of the hydramatic 3L30 in the trackers. This is a transmission flush and it takes 9-10 quarts in this procedure.
Old 05-17-2011, 12:39 PM   #7 (permalink)
colonelhogan44's Avatar
colonelhogan44 is on a distinguished road
A flush is a totally different animal. I was able to get more than 4 quarts into mine after blowing all the fluid out of the cooler lines.
NEW MANUFACTURE: 89-94 soft top clips - $50/set shipped -- 3 tailgate and 2 side window, lifetime warranty - PM for details.
1993 Tracker 4x4, 2 door, 8v, 3 sp auto. 132k - 25 mpg
1996 Tracker 4x4, 2 door, 16v, 3 sp auto. 100k - 28.6 mpg
1998 Saturn SL2, 4 speed auto, 206k - 35 mpg
1987 Mercedes-Benz 300D turbodiesel, 4 sp auto, 143k - 28.7 mpg
colonelhogan44 is offline   Reply With Quote Quick reply to this message
Old 05-17-2011, 04:48 PM   #8 (permalink)
bog
Banned
its here
depends on methods, and the vents are normal
94 FSM
page 7B17 3L30
2.9Liters pan off
5.1liters OVERHAUL ( every drop gone ,worst case)
1 liters = 1.05668821 US quarts 5.1 x 1.056 = ? ( use 4 banger)
a liter is a tiny tad long quart. LOL!
and btw , casting differences , variances, can change volumes a bit.
Old 05-17-2011, 04:51 PM   #9 (permalink)
bog
Banned
to do a full flush it means using more that max capacity.
why.?
because during the procedure of sucking new fluid, the new gets mixed with old.
the law of diminishing returns ,is in effect.
there is no TC drain, therefore there is no other way.
Old 05-17-2011, 06:33 PM   #10 (permalink)
Thank you for all the replies. Well, it ended up taking about 4 1/2 quarts to top of the level on the stick.
