Welding front and rear diffs - Suzuki Forums: Suzuki Forum Site
Old 09-08-2010, 01:18 PM   #1 (permalink)
john.vail is on a distinguished road
Default Welding front and rear diffs
I have a 93 Tracker, its going to be trail only. We are going to start with welding the diffs. The reason for this is its a budget build only. As of right now I have about $200 total into it and want to keep it as low as possible. I already understand the issues I will be facing welding the Diffs, what I want to know is how to do it, and if anyone has any pictures of if being done and could talk me threw it a bit.
john.vail is offline   Reply With Quote Quick reply to this message
Old 09-08-2010, 04:43 PM   #2 (permalink)
I know someone has done this please if you can help me out I would appreciate it.
Old 09-08-2010, 06:24 PM   #3 (permalink)
aquanaut20's Avatar
Welcome to the Forum.
Some folk do not have the capacity to use the Google search function and expect someone else to do the leg work.
I know you are not one of those lazy SOB's so I am suggesting you read the information in this link. How to Weld a Rear Differential | eHow.com
Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
99 Tracker, 4dr, 4x4, 2L DOHC, auto 200k
Old 09-08-2010, 07:04 PM   #4 (permalink)
SlimJim16v is on a distinguished road
Pedantic Old Ninja
UK (Spanish) 98 Vitara 2dr, JX tintop, 1.6l 8v SPI G16A (OBD1), 5sp manual, 4.875:1, 40k, 4x4, Manual Hubs
SlimJim16v is offline   Reply With Quote Quick reply to this message
Old 09-08-2010, 11:25 PM   #5 (permalink)
By far I am not that guy, kind of figured the back out, but there is no diff cover so I was not 100% sure how to go about it, but then again guess I shouldn't ask for help on a forum, no one is here to help everyone wants someone else to do all the looking thats fine Ill go some where else. Thanks for all the helpful insight but. I guess when you think you know everything that you dont need to share it with anyone. Thanks so much for showing me all that great 4x4 spirit I hear so much about. WOW
Old 09-08-2010, 11:29 PM   #6 (permalink)
Oh and thank you for referring to me as a son of a bitch. Honestly was just trying to get some direction not to have someone to come weld it and hold my hand. seeing as after this post I am sure I will be band from the site. You guys have by far treated me with the most disrespect. I have done my research but couldn't find the answers I needed. Screw it though Ill figure it out thanks so much again. I hope one day I don't treat anyone to ask me for advise the same way.
Old 09-09-2010, 06:54 AM   #7 (permalink)
Sævar Örn's Avatar
Sævar Örn is on a distinguished road
Welding the diffs is not much trouble, but along come other weak sports, like the ring and pinion teeth, they like to snap under tension, and the axle shafts, they do too..
But welding the diff itself really isnt that much trouble, just make sure all oil is cleaned off perfectly before making the weld, put the machine on the highest amperage you can handle(there is no such thing as welding a differential too hot)
Just make absolutely sure that no weld goes into splines or grooves, what I like to do when welding differentials is not only welding the spider gears together, but also welding them stuck to the differential casing itself, this ofcourse ruins the casing for later use, but these are not expensive to find at a wreckers site anyway, and you get a weld that never breaks, something else will break first.
I hope there was no disrespect from my end, at least not intentional.
Just don´t weld it like this guy did...
1997 Suzuki Sidekick G16B 33" mod - 208 kms
1997 Suzuki Vitara G16B - 33" mod - 178k kms
1995 Suzuki Sidekick G16B - 30" - 142k kms
Owner and webmaster of Icelandic Suzuki 4x4 club site http://sukka.is
Sævar Örn is offline   Reply With Quote Quick reply to this message
Old 09-09-2010, 07:05 AM   #8 (permalink)
mongoosevrx's Avatar
Gallery: 13
mongoosevrx is on a distinguished road
I would recommend NOT welding the front. you will have a really hard time turning the vehicle it's more important that front wheels can turn at different speeds than rear wheels. I think welding the rear should be enough for any wheeling near-stock trackicks attempt. Mine is a super budget friendly wheeler with both diffs open, and it's a blast. Anyway do the rear first and see how much you like it.
Don't give up on this forum, but check out zukiworld too, they have some pretty good info too.
'93 tracker two door
4x4 manual hubs, 5-speed
1.6l 8v 131,000 miles?
2" coil lift
2.5" body lift
2" wheel spacers with 30x9.5 tires
mongoosevrx is offline   Reply With Quote Quick reply to this message
Old 09-09-2010, 07:42 AM   #9 (permalink)
Come on - the guy understood the issues he was going to be facing.
I took him at his word - should I be the one to tell him that in mud he will have no steering control? He'll fight the steering to full lock (but he's got power steering - right?) and the vehicle will continue to travel in a straight line. It will "push" or understeer, and he's going to break axles and sooner or later (sooner rather than later) the third member, like if it was made of glass.
He already understands those issues.
Now - I know that somewhere out there on the internet, is a thread which shows all four differential gears being removed and alternate groups of teeth filled with welding bead and the differential reassembled with no welding to the hemisphere - I know this because I have seen it - but I am just too lazy to go search for it, so that I can post a link to it.
Of course if I wanted to use it as an example of how to my weld my diff (which I have no intention of doing - because I understand those issues), I might have more motivation to search
Old 09-09-2010, 07:47 AM   #10 (permalink)
Sævar Örn's Avatar
several images, welded differential - Google Search
