help on charging system - Suzuki Forums: Suzuki Forum Site
Old 06-30-2010, 10:58 AM   #1 (permalink)
bubba is on a distinguished road
Default help on charging system
i have a 1996 sidekick and my alternator will not charge the battery and both are brand new.
bubba is offline   Reply With Quote Quick reply to this message
Old 06-30-2010, 01:10 PM   #2 (permalink)
mirageman's Avatar
mirageman is on a distinguished road
you sure? go to autozone or a couple of other big name part stores. they will hook up your car battery to a device that will tell you if the battery or alternator or both are bad. do it now, because the testing requires a well-charged battery. it's free and then you'll know where to start looking. could be as simple as bad connections or bad wire/ground. get the free test first though.
1997 stock Cami tracker california emiss 1.6L 5 speed 4x4, 15" alloys, cruise control, AC. 2-door soft top for the summer, yee haw! ......Superwinch manual hubs and Snowbear Plow for the winter..... YEEEEEEE HAWWWW!!
mirageman is offline   Reply With Quote Quick reply to this message
Old 06-30-2010, 01:14 PM   #3 (permalink)
mirageman's Avatar
it certainly is possible that you got a bad alternator right out of the box. what happened that you needed to get a new battery and alternator? this same reason? if you don't want to go to the store to check it out, put a voltmeter on the battery and read voltage, should be close to 12volts. then turn on the vehicle and again put the voltmeter on the battery and read voltage. if it is significantly higher, it is charging (14.x volts or so)
Old 06-30-2010, 01:29 PM   #4 (permalink)
yea but its the 5th one i have put on this car
and they all have been from autozone.
Old 06-30-2010, 01:32 PM   #5 (permalink)
i know for a fact that the alternator is not charging my battery because i hooked a voltmeter before i started the car and it was around 12.2 then i hooked it up with the car on and the volts went down
Old 06-30-2010, 03:11 PM   #6 (permalink)
Section Moderator
Some interesting info and ways for you to check your alternator here:
charging system diagnoses
'61 NSU Quickly - 150mpg
Old 06-30-2010, 04:33 PM   #7 (permalink)
i just took it to autozone and the battery was dead when i got there
Old 07-01-2010, 05:49 AM   #8 (permalink)
Section Moderator
It is practically impossible or 5 new alternators to be bad. So it must be something with the wiring or the ground. You need to check/trace your wiring, one by one.
Old 07-01-2010, 09:04 AM   #9 (permalink)
mirageman's Avatar
they do the fast charging for free too, takes about 45 minutes if your battery is still good and rechargeable. if it isn't, you'll need a new battery anyway, so I'd get one and have them test it again in the parking lot, battery and alternator. how new is the current battery? is it a sealed type or can you open to fill with distilled water to the full mark? a dry battery will not work. hope that's it.
Old 07-01-2010, 12:12 PM   #10 (permalink)
i have traced all the wires from the alternator and the battery
