Suzuki-Forums.com is the premier Suzuki forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 02-08-2010, 05:45 PM   #1 (permalink)
canyncarvr is on a distinguished road
Default Unintended consequence
A good one, 'fer once.
'89 Tracker 1.8 8V TBI
Symptom: A good bit of 'jerk' in transition from decel to accel, like the driveline had a whole lot of slop in it. No TBI stumble, tach didn't jerk..it just felt sloppy.
Separately, a surging idle problem was resolved by cleaning the ICS. Idle is fine now..up about 150RPM when lights or blower is turned on.
Set the TPS switch, that transition was way off the mark.
The unintended part? The 'jerk' is gone! Decel to accel transition is smooth as butt'a now.
While the symptom could have more than one cause (like an honestly sloppy driveline), if another rig has a similar symptom, making sure your ICS works like it should and a TPS calibration might be helpful.
Hope this is helpful to someone.
Cheers!
canyncarvr is offline   Reply With Quote
Old 02-09-2010, 07:17 AM   #2 (permalink)
Good advice. That poor ISC vibrating billions of times in 22 years. Surprising what a little clean up and calibration can do.
Old 02-09-2010, 08:11 AM   #3 (permalink)
mirageman's Avatar
mirageman is on a distinguished road
""""Separately, a surging idle problem was resolved by cleaning the ICS.""""
--- sorry, but does ICS = idle control screw? by that do you mean the idle speed adjusting screw?
mirageman is offline   Reply With Quote
Old 02-09-2010, 08:17 AM   #4 (permalink)
No, its is the idle switch circuit (or idle speed controller) that is run by the ECU for the idle. This is what keeps your idle at a constant, even with accessories on, among other things.
EFI-sensor-theory
(And frankly, if idle is off, it is rarely because an adjustment is needed on the idle control screw - usually other stuff).
Old 02-09-2010, 09:05 AM   #5 (permalink)
mirageman's Avatar
EFI-sensor-theory
I guess he meant ISC then instead of ICS, my goodness, I thought there wasn't much to these trackers!
Old 02-09-2010, 10:07 AM   #6 (permalink)
Ha!
I typed 'ISC'..re-read it and thought..'Wait...it's Idle Control Solenoid...not Idle Solenoid Control!
I did a search on the site for 'ICS', found a number of threads using those letters..so I edited my post.
Sorry. Indeed, it is Idle SPEED Control. There is of course a Solenoid in there..but it's not the 'S' in ISC.
ops:
