95 geo tracker fuse block - Suzuki Forums: Suzuki Forum Site
Old 01-10-2010, 07:48 PM   #1 (permalink)
purple trapper is on a distinguished road
Default 95 geo tracker fuse block
there is one wire coming off the ignition coil meter fuse (15amp) it is black with a white line, it keeps blowing fuses is there supposed to be another wire coming off of the ignition coil fuse?
thanks
purple trapper is offline   Reply With Quote Quick reply to this message
Old 01-11-2010, 08:26 AM   #2 (permalink)
ranger88den's Avatar
The wire feeds many components through splices such as ignition coil, generator, fuel pump relay, etc. You have an 8v or 16v?
Old 01-11-2010, 02:31 PM   #3 (permalink)
95 geo tracker 2 door, 4wd, automatic trans, 16v 1.6l. realized theres a common ground for the block, still blowing fusres, is it the fuel pump relay? corosion on the fuel pump ground? pulled the dash and have access to most of the wires but have not found anything burnt or shorted yet, also have random wire and random clip near carb that i do not know what it does, but it looks as if it has been cut or ripped somehow.
Old 01-12-2010, 12:37 AM   #4 (permalink)
its the ignition coil meter fuse bro.
Old 01-12-2010, 11:47 AM   #5 (permalink)
Banned
top fails: ah bro
o2 sensor shorted or wires to it.
Old 01-12-2010, 03:39 PM   #6 (permalink)
where is that located.
Old 01-12-2010, 09:51 PM   #7 (permalink)
Banned
here.
Old 01-12-2010, 09:54 PM   #8 (permalink)
Banned
the wire if no longer routed like oem , then it hits manifold and melts and shorts.
top fail for this feed .
or the O2 is shorted inside. (even draw for both)
look ,if looks perfect, pull connector to O2, if fuse dont blow, bingo ,bad 02 heater.
all modern cars suffer from this.
Old 01-12-2010, 10:44 PM   #9 (permalink)
what color is the wire.
Old 01-12-2010, 11:01 PM   #10 (permalink)
Banned
my sig has my web site. it's all there.
all things make motor go are there. see schematic section.....
same wire as you told me black with white stripe in post 1.
see it, see it the O2 heater , left side just below pin A23
click this link, just below this line.... bingo, the whole EFI wiring .
http://kick-fix.com/ECU/92-95MPI-eng...-size-huge.png
