Old 11-10-2009, 09:21 AM   #1 (permalink)
mchutton33 is on a distinguished road
Default 95 Geo Tracker Transmission Photo question
I have a 95, USA Geo Tracker, Automatic, 2 wheel drive. I was crawling around under it to change the oil when I noticed what looks like a little door panel missing at the bottom of the transmission. I bought a Haynes repair manual in hopes of finding what the door is and if it will hurt anything being gone. The book has just about everything except a picture of this little door. Can someone tell me what this door is for, it's name so I can order a new one, and if you know where I could find a new one that would be great as well. I have attached a picture looking up towards the transmission.
Thanks.
mchutton33 is offline   Reply With Quote
Old 11-10-2009, 11:48 AM   #2 (permalink)
Turbo_Crazy is on a distinguished road
All that is, is an access panal at the bottom of the transmission so you can see up and in to look at the flywheel. U really don't need it but if you want one go ask for the transmission access panal on the bottom of the transmission.
Might have to go to a dealer to get it.
Turbo_Crazy is offline   Reply With Quote
Old 11-10-2009, 12:19 PM   #3 (permalink)
keithert's Avatar
keithert is on a distinguished road
Is that a 3 speed transmission? Mine has the same hole, but I didn't think the 95 used the 3 speed.
1992 Tracker - 1.6 8v engine with automatic trans
2002 Mitsu Montero Sport
RIP
1990 Tracker - 1998 Wrangler SE
keithert is offline   Reply With Quote
Old 11-10-2009, 04:46 PM   #4 (permalink)
Ya i am pretty sure they all have it.
Old 11-10-2009, 08:09 PM   #5 (permalink)
I can get one at a junkyard around here if you really want it. Just put some duck tape on it now. You could go here and contact them: OEM Suzuki Parts
Or try your local Suzuki Dealership for the part even though mine told me a cable is discontinued yet I have one coming to my front door tomorrow... go figure.
93' 2dr Geo Tracker 4x4 5speed, 8v 1.6L, auto, 157k
95' 2dr Geo Tracker 4x2 3-speed auto, 8v 1.6L, 132k
http://gofastforless.com - Great information on ignitions.
Old 12-15-2009, 06:36 PM   #6 (permalink)
Most likely made of rubber. Used to access the 4 torque converter bolts when removing the transmission. Always good to have in place-keeps road dirt and grime from entering.
Old 12-15-2009, 06:54 PM   #7 (permalink)
aquanaut20's Avatar
I thought it was the trap door where the mice go in and out for shift change.
Learn something new every day...
92 Ford Explorer, 450k
97 Ford Explorer, 360k
99 Tracker, 4dr, 4x4, 2L DOHC, auto 165k
aquanaut20 is online now   Reply With Quote
Old 12-16-2009, 07:58 AM   #8 (permalink)
cmays03's Avatar
cmays03 is on a distinguished road
yes the 95 had the 3 speed i have a 95 and it has the 3 speed in it. that cover is made of plastic and i lost mine too. I use my tracker off road and in the mud all the time and never had a problem with the mud getting in there or causing any problems. you will be fine without it but if you want it then by all means get one.
95 geo tracker (16v)chevy 2.8 v6 coming soon, auto, removable hardtop, dana 30,35 axles custom 3 link front, custom 4 link rear, 33" tsl's, welded rear, smittybilt 8k winch.
cmays03 is offline   Reply With Quote
Old 12-16-2009, 08:47 PM   #9 (permalink)
kick-fix's Avatar
id kill for a car with only that as an issue.
it stops the rats and mice from nesting and saves the TC bolts as they fall off.
few posts back , exactly.
Signature:
http://www.kick-fix.com/
Post your car spec!, what ARE you driving? Please!
96 Tracker, 5sp, 2Dr,4w,d OE stock.Fed48+No A/C ,No Cruise. +MPG gauge. a new 97 today 2wd 4dr cracked block.
Lets avoid shot gunning or guessing or working with out tools. I will help you the best I can! I can't see or hear/feel your motor, so consider my answers, in that light. You can rent most tools.
There are 2 diagnostic paths, one with tools and one without! Which way?
