bad AT tranny, you didnt say which you have 4sp or 3sp automatic ,obviously]\
hehehe, how had gas , you are car ,? heheheheheheh
So this car squack is, transmission failure , after hot soak.
this is when the tranny lube is at its hottest (not pulling heavy loads)
you did say what it does.?
just tray in neutral ?
i can presume the shifter does move to D position and wiggling it there dont help it.?
if tranny is bad, and not just linkage.
id say :
1:check the fluid level per glove box guide.
2: get full power flush with new intranny filter swap (or screen as the case may be)
then if not fixed.now we need to run lots of test.
http://www.kick-fix.com/
