At the top of the list is top-heavyness followed by the real possibility of the 4-inch mounts bending or collapsing under stress.
Then there is the ga -I mean Festive - factor... You'll be need to be running humongus tires in order to keep the giggles to a minimum. Those humongus tires will end up ripping the stock drivetrain to pieces.
TracKicks are not the easiest trucks to lift and a 4-inch body lift would be a bad start despite the apparent ease of such a lift. 2 inches would be more reasonable.
There are other details - like remounting the radiator - that I'll leave to others for explanation.
I hope that this helps!
- Ack
Ack's FAQ
nearly 600 searchable links to the Samurai/TracKick
you could do a 2" body with a 2" suspension lift - check out CALMINI.... just a thought
Yahh, dats what I did, 2" spring spacers w longer shocks and strut spacers, and then added the 2" body lift. Except I went for the lowrangeoffroad.com as the supplier.
2 inch Spring spacers, and strut spacers ... $130
2 inch Body lift ... $120
MarkB.NV
1991 Tracker, 8valve 1.6L, 5 spd, 4x4, 2 door, soft-top, 103,xxx miles, w/ 2 in suspension 2 in body lift, 30x9.5/15 MT tires.
2'" would be the way to go check out this site - - - DIY 2"bodylift - - - Its step-by-step instructions on how to do it. Lots of good tips and what you need to watch for... I did it on my first zook when I was just a little mud hopper and I didnt have too many issues - check it out - should be helpful
good luck
Kyle J. Ferrari
HARDCORE INC.
1994 Suzuki Sidekick, MADE IN CANADA, 16 valve, 1.6L,4X4 - MNL Hubs, 5 spd Manual, Pwr Steering, 2 Dr,
Aftermarket: Removable Hard Top, Cold Air Intake
i did a home grown 3 inch body lift and 2 inch spring spacer kit ..and 235 75 15 tires.. imo this is just about max .. could run bigger tires but think ur pushin having to do gears .. their bigger lift kits but they drop the diffs and i dont see the point of that .. its bigger you go the closer u get to the roll over point .. just my two cents
I think the 2 inch body lift would be better. Any big issues doing that?
No, it's pretty easy, just be careful of all the hoses and cables and wires. I had to loosen the fuel filler hose on the gas tank and move it out about 3/4 of an inch. Also had to loosen the charcoal canister mount during the lift process, then bolt it down again when I was done. Also keep an eye on the front brake hoses - you don't want to stretch those.
It took a few tries to get the shifter levers setup at the right angle. Had to remove them and heat them with a torch-bend them backwards a bit. I laid them down on cardboard and traced their outline at the start, then figured I wanted to top of the shifter to be bent back about 1.5-2.0 inches. Heat it and bend it, hold it up to the cardboard template, repeat until it matched the target outline. Let it cool, then install and test. Try again. Finally got it right.
MarkB.NV
