Old 11-01-2009, 01:44 PM   #1 (permalink)
The K is on a distinguished road
Default Suzuki Vitara Fuse
Hi the tail light and dash fuse keeps blowing help
The K is offline   Reply With Quote
Old 11-01-2009, 02:56 PM   #2 (permalink)
Might be helpful if you post the year of your car, 8v or 16v, auto or manual tranny, etc. See sticky note on forum for what to post, otherwise people can't help you. It would sound that you have a short somewhere. Or perhaps bad ground. Here is list of grounds on some Trackers:
common-failures
If I'm not mistaken, this would be the #3 fuse/15a for markers, interior lights and tail lights, no? Or is it more than one fuse (radio and cigarette lighter still lit?) You need to be a lot more specific.
Bex is online now   Reply With Quote
Old 11-01-2009, 03:23 PM   #3 (permalink)
Yes this is the fuse #3 fuse/15a the lights fliker when I go over a bump and then fail
The K
Suzuki Vitara JX H/Top 8V, 1.6L, 5 sp, 4wd, 2dr SWB 1998 Spanish Build
Old 11-01-2009, 08:45 PM   #4 (permalink)
kick-fix's Avatar
check left rear behind tail light, for trailer conn. and bad wiring hack job there.
but this line is the longest in car, and will be very hard to find.
injpection of whole harness hear all parking lamps all.
http://www.kick-fix.com/
kick-fix is online now   Reply With Quote
Old 11-02-2009, 05:31 AM   #5 (permalink)
I had similar problem with lights flickering when hitting a bump (although they stayed on). Harness comes out of firewall just to the right of the battery. I had some corrosion there - rusty bits which eventually rubbed through the insulation of a couple of wires - they would only touch when I hit a bump, etc. Did easy re-insulation of wires, and all was ok. So, aside from checking ground behind the rear taillight(take lens off and you see it, many people have rust/corrosion issues there), you may want to check the wiring in engine compartment too.
