snake-oil
IAT:
The intake air temp, sensor on 16v, is only a fine tweak of air density, in fact some 92 , are missing it completely.
On TBI IAT is very effective ,and vary effective at killing close loop. and the gross effects of that.
next is the ECT, but car goes to closed loop and runs there, as ECT reaches over 150F should enter closed loop no matter , unless WOT.
That leaves only 2 more devices.
THE MAF and the o2.
the o2 liar box is complex, most cars will reject any liar box that does not look like a swinging O2 sensor sig.
(the out put of the sensor must not go to high. it must not go to low and it must react to the the ECU AFR changes, if it dont the ECU my reacted in strange ways (89-95) it may slam rich or too lean. (bad design, it should go to intrinsic mix, like other cars)
on the old kicks it may go gross rich or lean and will not even realize ,why it can not adjust mixture properly , dynamically.
the maf sensor liar box ( offsettiing device ) works in WOT only, if you move it too far and the motor cant enter closed loop.
the new cars fail with DTCs if you do this old kicks it looses control and slams to fully rich or lean. depending on your actions.
WOT ,cuts O2 usage on all motors.
so the only truly effect mixture fooling device is the O2.
( i wont discuss fuel pressure, as that too will make CL fail)
the only trick then is to make a device that shifts the O2 sensor , to lean or rich and only tad.
here is the basic idea.
not saying this works, there are way to many to evaluate.
but it is possible to offset an O2. and it must be done very carefully.
no guarantee the ECU dont dump this device and throw DTC codes or go crazy, (railed AFR)
i like his honesty on how hard it is to work on obd1.
