I've thought about it, my buddy took his off a '97 wrangler after I talked him out of buying the very expensive quick-disconnect type. His links broke several years ago so I told him, you've been driving around without the sway bar engaged for years... why do you need it now? i didn't think his jeep swayed very much, but his suspension is way more stiff than my tracker's
I'd say keep the speed under 50mph around clover-leaves and you'll be fine. Not sure how much more articulation you'll get out of if. Try disconnecting the links, driving around for a while, then make your decision. I've thought of doing this before, just never got around to it.
'93 tracker two door
4x4 manual hubs, 5-speed
1.6l 8v 129,000 miles?
2" coil lift
2.5" body lift
2" wheel spacers with 30x9.5 tires
