Old 10-27-2009, 09:09 PM   #1 (permalink)
Jasenford is on a distinguished road
Default 89 Tracker stalls when cold
i recently bought a new(used) throttle body with ISC, Injector, and TPS.. Everything runs fine, idle is decent when hot.
Anyways after i put this new TB on, the car will keep stalling until it gets to normal temp, unless i turn the heater on.. Im not to sure what to do from here, and its not really a big deal since i was finally able to pass smog..
Any advice would be great
P.S.... 8V 1.6L 5 speed.. Motor has good compression, timing is 8 BTDC, idle screw has been turned in quite a bit to try and compensate for the engine stalling but no luck
89 Tracker 1.6L 8V 5speed 4x4
CA, USA, flowmaster muffler, cold air intake, Pathfinder AT 31x10.50.x15 Tires
Jasenford is offline   Reply With Quote
Old 10-28-2009, 06:21 AM   #2 (permalink)
Just a thought...normally when you turn the heater on (or fan) the idle would drop then ISC (or IAC in 89??) would regulate idle. You say that when you turn heater on, idle raises to keep car going. So maybe something in that area??
Bex is online now   Reply With Quote
