I'm curious the amount of oil a 92 1.6L will take .. I did an oil change 5.2L is the amount I read .. it won't read on the dipstick is it the right dipstick? My dipstick is 13 inchs long past the plunger...? it doesn't even look like it will go into the oil pan ..?
Also, are you sure you have stick in the whole way? My stick will only go completely down when it's inserted in one 'special' way. If stick is off of this angle, it goes in, but will not go the whole way down the shaft. You have the right stick - mine is 13 inches past the plunger too.
On all my 8vs{3} you can only see the oil on one side of the dipstick,don't know why.The sticks all have to be put in just so.
I took the dipstick out of a 16v,it has a different end{the outside end}doesn't help,still oil on one side,I just like the look of it.
just a quick tip see the two holes in the dip stick the low and full mark it takes approx
1qt to fill it from the bottom hole to the top hole. i guss this will only help people in the states.
