Old 10-25-2009, 03:02 PM   #1 (permalink)
kevinstracker is on a distinguished road
Default Replace compressor with idler on 91 tracker
The ac compressor seized up, belt broke and goodbye power steering. Does someone make an idler pulley and arm to replace the compressor completely? We just got the car and are not really concerned about ac here in north jersey. It's the little 8 valve engine, in a two door hard top with auto trans. It's 4 wheel drive. This belt only drives the ac and power steering from the crank pulley. Any help will be appreciated. Thanks.
kevinstracker is offline   Reply With Quote
Old 10-25-2009, 03:09 PM   #2 (permalink)
mashaffer's Avatar
mashaffer is on a distinguished road
Just a thought but could you just install a belt from a non AC car?
mike
mashaffer is online now   Reply With Quote
Old 10-25-2009, 03:13 PM   #3 (permalink)
Paladian's Avatar
Paladian is on a distinguished road
thats what i would do. find a smaller belt
_____________________________
Vitara (sidekick), 1990, 1.6 (59kW din, 80HP, 1590CC), 4x4, 8v, 5 speed, hard top, made in japan
Paladian is offline   Reply With Quote
Old 10-25-2009, 03:41 PM   #4 (permalink)
mike
Can't, because the belt adjustment on an ac equipped car is on the ac bracket. But, you could go to a junkyard & get a power steering bracket off a non-ac car with power steering, it should have the adjustable mount.
I've seen ppl ask this before, & I don't think anyone makes a pulley that would work to just take the place of the compressor.
Fuzz
Pioneer Sound system
fuzzy1 is online now   Reply With Quote
Old 10-25-2009, 04:10 PM   #5 (permalink)
Fuzz
If you look close at the p.s bracket, you can bolt into a stationary position for use with a/c (as the adjuster) or mount in it's adjustable position. At least this has been my experience with the Trackers I've worked on.
1996 Geo Metro LSI, 2 dr hatchback, 1.3, 3 spd auto
1978 Jeep J 10, p/u, 258 c.i., 3 spd manual, 4wd
Old 10-25-2009, 04:43 PM   #6 (permalink)
ack
This may be from the Moronosphere, but here goes...
The AC compressor is driven by a magnetic clutch - which freewheels unless there is a current applied to it.
That said, have you disconnected the wire that drives the magnetic clutch??
It might be possible that the clutch is being powered all the time when you turn on the engine...
Again, just tryin' to think about every possibility.
Otherwise, the a non-AC bracket from a salvage yard/pick-n-pull is the best solution.
- Ack
Ack's FAQ
nearly 600 searchable links to the Samurai/TracKick
'88 Samurai Offroader
'02 Tracker ZR2 4-door Daily Driver
ack is offline   Reply With Quote
Old 10-25-2009, 06:14 PM   #7 (permalink)
Default ac compressor removal, etc
Thanks, everyone. I thought Fuzzy diagnosed the situation correctly, but I've begun getting the crap off the power steering bracket to see if it can be adjusted. It's too dark and cool to finish this quest tonight. It's in an awkward spot down under the compressor. The clutch on the compressor was seized up when the key was off. It took some muscle to get the pully to turn at all. We'll see how it goes.
Old 10-28-2009, 11:21 AM   #8 (permalink)
I think this subject was covered back in July under the power steering on 1991 tracker subject. Looks like I'll be able to adjust the ps bracket after all per cmays03. Thanks.
Old 10-28-2009, 07:27 PM   #9 (permalink)
Mike O'Toole is on a distinguished road
I was able to remove my compressor from the platform and put a smaller belt on my 93 tracker. Air conditioning was dead anyway so I removed it when I replaced my leaky front oil seal
Mike O'Toole is offline   Reply With Quote
Old 10-29-2009, 04:46 PM   #10 (permalink)
It works but not from up top and definitely following the FSM on removing ps pump. I tried to get around removing the oil filter, but don't bother. The bottom bolt has to be removed from its threaded hole and repositioned in the adjustment track or slot. I'm just leaving the compressor where it was so someone else can fix it if they want. Try to clean this area up pretty good so you can see what you are doing. I haven't had black, greasy knuckles since I was a high school kid over 50 years ago. Do buy the factory service manual off ebay if you can- abt. same price as catch all cover all years Haynes.
