it is your belt. i have the same problem with mine. replaced the belt and about 2-3 months later it started again. so i bought a can of spray that stops the belt from sliping and squealing  i did think of tightning the belt but was a bit worried if it went tighter that bearings in water pump and alternator would die. does anyone have any good way of knowing how tight to have belt?
_____________________________
Vitara (sidekick), 1990, 1.6 (59kW din, 80HP, 1590CC), 4x4, 8v, 5 speed, hard top, made in japan
