Old 10-24-2009, 11:19 PM   #1 (permalink)
savwafare10's Avatar
Gallery: 7
savwafare10 is on a distinguished road
Question changing cv boots
I have pulled half shafts before,but not on a tracker. Does shaft clear and come through spendle or does it all have to come apart? thanks....on a budget or I would just replace all of it.
rice is cheaper than gas
92 GEO tracker lsi 1.6L8V 4WD 5 spd
savwafare10 is offline   Reply With Quote
Old 10-25-2009, 04:34 PM   #2 (permalink)
ack
The halfshafts must be removed from the rear side of the hub assembly.
Doing this is relatively simple on the driver side as the halfshaft bolts to an axle shaft flange with three bolts. The passenger' side (or the right side in the UK) halfshaft has a slipjoint that fits into the differential sidegear. Because of this, you have to do more disassembly at the hub in order to remove the halfshaft.
Here is a direct link to the section of the '96 Tracker Factory Service Manual Project at Ack's FAQ that details the process:
'96 Tracker Factory Service Manual Section 4C
Ack's FAQ: Your 4X4 Portal To All Things Suzuki/Geo
An index to the entire '96 Tracker FSM can be found at:
Index
Unfortunately, due to other more pressing (bathroom remodel) projects, I have not integrated all the sections into the main database, so this index is currently the best way to find stuff in the Tracker FSM...
Finally, here is an article I wrote describing how to diassemble the Halfshaft to replace the boots yourself:
Halfshaft rebuilding
The hardest part is making secure the metal straps that hold the new boots in place. If you have the tools to do it, go for it! Otherwise, buy a rebuilt set and turn in you old ones for the core charge.
I hope that this helps!
- Ack
Ack's FAQ
nearly 600 searchable links to the Samurai/TracKick
'88 Samurai Offroader
'02 Tracker ZR2 4-door Daily Driver
ack is offline   Reply With Quote
Old 10-25-2009, 11:41 PM   #3 (permalink)
Gallery: 7
Thumbs up Thanks
Doesn't sound to bad. I would if I could aford it, replace the shaft. I just bought this a few months ago, Just try'in to get things done before the snow flys. At least there will be grease and new boots.....There are no noises(i.e. clicking while turning) coming from them yet. I guess I'll see how bad they are once pulled apart. Thanks for the site and info. Makes it easyer what to expect before tear down. Eather a 6pack or a case a beer. Or go straight to the wiskey....
Old 10-26-2009, 08:47 AM   #4 (permalink)
mongoosevrx's Avatar
mongoosevrx is on a distinguished road
I just replaced the passenger(right) after an unfortunate hill-climb attempt. I got a re-manufactured shaft for $60. and a few more bucks for some hardware. The strange thing was the core charge of $80.
mongoosevrx is offline   Reply With Quote
