i got an 89 fsm , right here.
do not hook up the red arrow until you are sure.
this Fuel pump regulator sends vast quantities of fuel back to the gas tank.
so, all you have to do is, look.
look at the 3 lines to the tanks, see em.
one is pressure , goes to TB rear port.
one is return, goes to Red arrow above , DO NOT GUESS , DANGER !!!!!!!!!!!!
last is vent for tank (goes to evap canister)
this system is under huge pressures. 35psi, (not like a carb at all at 5psi)
cool a basket case.
we love em.
there are axle vents , NO
there is tranny vent, NO
there are EVAP vents, NO.
what more things are hangine.
the vents had ,plastic caps new ,keeping out bug.
but they get lost (caps) and look like they are missing. typical , basket.
ok attached is the fuel feed and return dwg.
hose 27 goes to pipe 7 , then hose 28 then to tank vent return.
no way else.
http://www.kick-fix.com/
