Old 10-12-2009, 06:41 PM   #1 (permalink)
mongoosevrx's Avatar
mongoosevrx is on a distinguished road
Default anyone bust off a front diff mount before?
Great site! After searching around, I'm starting a new thread. I have a U.S. 1993 tracker 2-door 4x4 with the 1.6l and a 5 speed. Off roading a couple weeks ago I just about fried a cv joint durring a hill climb. This past weekend i was replacing the half-shaft and noticed the ear mounting the front diff to the engine crossmember was cracked all the way through. When the diff is loaded, the bolts used to attach the shaft from the t-case to the yolk rub against the crossmember (and nearly shaved in half!). Has anyone broke this mounting "ear" before? What would you suggest for an easy fix? All I've come up with so far would be to make a bracket to run longer bolts through and wrap around the diff, or take the whole cover off and weld the two pieces back together(which I'm not too crazy about, being it's cast aluminum, and very thin, and it broke once already). Thanks
mongoosevrx is offline   Reply With Quote
Old 10-12-2009, 07:47 PM   #2 (permalink)
a picture from underneath with me holding the broken piece in place
Old 10-12-2009, 07:50 PM   #3 (permalink)
and one with the mount in position
Old 10-13-2009, 12:14 AM   #4 (permalink)
obradleyo is on a distinguished road
That is a pickle your in. I had ro replace mine, they usally break this way... I just looked for a link to help you but i couldn't find it. the guy makes a bracket that wraps compleatley around it
1995 Kicker 5 speed, 4 dr, 4wd, Ac,Ps 16v 31" TSL's,Calmini 3+3, torquer cam, magna flow with 2" tail pipe, calmini steering stablizer....... Sacramento,ca
obradleyo is offline   Reply With Quote
Old 10-13-2009, 07:06 AM   #5 (permalink)
relicduke's Avatar
M'lady broke our's in snowdrift last winter,I had some light chain that I tied it down with,left a little slack,just tight enough so it doesn't rub.I've towed some lesser vehicles,including a ford half ton out of a swamp,and it's holding up.
But then I've been known to be unconventional at times
relicduke is offline   Reply With Quote
Old 10-13-2009, 07:18 AM   #6 (permalink)
[quote=obradleyo;189782]That is a pickle your in. I had ro replace mine, they usally break this way... I just looked for a link to help you but i couldn't find it. the guy makes a bracket that wraps compleatley around it
I think thats what I'll do. Is this a common problem? Thanks for the help!
'93 tracker two door
4x4 manual hubs, 5-speed
1.6l 8v 129,000 miles?
2" coil lift
2.5" body lift
2" wheel spacers with 30x9.5 tires
Old 11-02-2009, 04:22 PM   #7 (permalink)
Got it fixed up, the yellow piece attaches to the pivot bolt on the rear a arm mounting point then strapped it down.
I ended up with 2 extra brackets, if anyone wants one, let me know. You would need to "modify" the factory crossmember. I just grabbed the lip with a vise-grip and bent it down a little to fit the new piece(took 2 minuets).
2" coil lift
2.5" body lift
Old 11-03-2009, 03:02 PM   #8 (permalink)
Rhinoman's Avatar
Is there anyone who hasn't? The only real solution is the steel diff casing and diff housing from a V6 GV or diesel model. Reinforcing the rear mount will just move the weak point elsewhere, the main housing will shatter next time.
