Old 10-06-2009, 06:00 PM   #1 (permalink)
LadyHawk is on a distinguished road
Default What other makes OEM wheels will fit my kick?
Wanting to know what other car company's wheels will fit on sidekicks? I have a '94 4dr 4x4 USA. I see great deals on wheels all the time, just don't know if they will fit my kick! Like today, wheels off a old ford with great near new 235 AT tires. Will it fit? Thanks guys.
LadyHawk is offline   Reply With Quote
Old 10-06-2009, 06:19 PM   #2 (permalink)
kick-fix's Avatar
got to match bolt pattern and 4wd hub. both..
then be min, width for your desired tires.
stock width is not good or safe for 235s, "ask tire maker, he dont lie"
the suzuki spec page has the data on the bolt pattern.
we have a list. but first the 94 spec.
offset 25mm
dia, 15" x 5.5"w
circle dia. 5.50"
studs 5x 12mm
there is a huge list i have posted here and many others many times this year.
next i will find that.
http://www.kick-fix.com/
Post your car spec!, what ARE you driving?
96 Tracker, 5sp, 2Dr,4w,d OE stock.Fed48+No A/C ,No Cruise. +MPG gauge. a new 97 today 2wd 4dr
I do not advocate of shot gunning or guessing or working with out tools/meters/scopes
but I will help you the best I can! I can't see or hear/feel your motor, so consider my answers, in that light.
There are 2 diagnostic paths, one with tools and one without! Please advise which path you wish to take?
kick-fix is online now   Reply With Quote
Old 10-06-2009, 06:20 PM   #3 (permalink)
kick-fix's Avatar
1st search returns.
http://www.suzuki-forums.com/suzuki-...tml#post171892
Old 10-25-2009, 03:22 PM   #4 (permalink)
rcmsr is on a distinguished road
Default wheels
old model ford truck wheels will work i found some alum. ones for mine
rcmsr is offline   Reply With Quote
Old 10-25-2009, 03:55 PM   #5 (permalink)
ack
ack's Avatar
Default wheel interchange
Here is another link (thre results of a search for wheel interchange at Ack's FAQs)
Wheel Interchange
Ack's FAQ: Your Information Portal To All Things Suzuki/Geo 4X4
I have a set of full-sized Ford Bronco aftermarket wheels on my Samurai.
The important thing to remember is that the center hole must be large enough to clear the Samurai/Tracker locking hub assembly (yes, you can interchange TracKick and Samurai wheels!) There are many wheels with 5 on 5.5" bolt hole patterns, but only the ones with a 4.25" center hole will actually work!
I hope that this helps!
- Ack
Ack's FAQ
nearly 600 searchable links to the Samurai/TracKick
'88 Samurai Offroader
'02 Tracker ZR2 4-door Daily Driver
ack is offline   Reply With Quote
Old 10-25-2009, 06:25 PM   #6 (permalink)
deeznutts77's Avatar
Gallery: 4
i have old ford van ones on mine. also older jeep wrangler fit. heres a link 2 some rim xrefrence.
http://fastwheels.ca/FCW2008AppGuide-Web.pdf
ours are 5x5.5 or 5x139.7
96 sport 3spd auto 1.6 16v 2dr geo tracker all stock
An eye for an eye makes the whole world blind. Mahatma Gandhi
