The tcases will physically swap. But the tcase output shaft spline counts differ.....89-95 output shafts are 26 spline.....96 and up output shafts are 16 spline.
so you will have to swap the yoke or whole shaft.
there are 2 shafts (rear prop shaft) and 1 mt (2dr/4dr) and 1 AT for 4door.
my small contrib.
cheers
http://www.kick-fix.com/
