Old 09-29-2009, 05:19 PM   #1 (permalink)
nellie is on a distinguished road
Default Known problems - 93 Tracker?
Just bought a 93 Tracker. It seems to run great, and it's looking good with new tires and soft top. I'll find out the truth next week when it goes to the shop for a full check-up and tune-up. My husband advised me to ask all of you if there are any known problems (see Tracker details in my signature, but sorry I don't know the valves or induction type) that I should ask the mechanic to take care of proactively.
Thanks!
Nellie
Canada, 93 Geo Tracker, 1.6 Liter, 3-speed automatic, 4WD
nellie is offline   Reply With Quote
Old 09-29-2009, 08:45 PM   #2 (permalink)
rickf is on a distinguished road
Welcome,
Good call for the tune-upcap,rotor,plug wires,fuel filter along with valve adjustment, just make sure good quality parts are used. Oil change for sure. And if it is unknown when the timing belt was changed last,this is a must do along with the water pump.
Check all the fluid levels and anti freeze, battery
Other things can be done to depending on the mileage
rickf
Current 2000 Tracker 2L 5 speed 4 door 4x4 103K
Previously owned 92 JLX 120K,93 JLX 230K,93 JLX 156K 96 Sport 135K
rickf is offline   Reply With Quote
Old 09-30-2009, 05:13 AM   #3 (permalink)
Cheaper to DIY than take it to a shop. Its the enjoyment of owning and buying a used car... otherwise you are just better off to buy a new one.
Old 09-30-2009, 07:06 AM   #4 (permalink)
Good advise from Cody and rick. Also keep an eye out for crank timing gear torque, EGR system maintenance, make sure all grounds are clean and tight, and the capacitors in the ECM aren't leaking. Get a factory service manual off ebay, as your husband or mechanic will need it sooner or later. This is Jerry's website, valuable info here:
The KickFix Repair Pages, for Sidekicks and Trackers
Welcome and enjoy your toy.
Old 09-30-2009, 11:59 AM   #5 (permalink)
Would be helpful if you had some kind of maintenance history from previous owner, like if timing belt has been changed already, etc. These cars are also prone to capacitors failing in the ECU, and most people have to change them at some point. Only a $5 job if you know someone who can solder properly. This is something your mechanic probably won't/can't do, but be forewarned!
