Front Coil Spring Replacement(lift)
I have a Canadian, 1994 Suzuki SideKick, 2dr, 4wd, Automatic.
I would like to replace the front coil springs and add about a 2 inch lift at the same time.
I would like to use, used springs from another vehicle to do this.
I raised the back by using Bronco front coil springs.
Does anyone know what kind of coil spring off another vehicle that would work. I can cut the springs down, but need to match the ID and OD of the current Suzuki Spring.
I read somewhere that a TJ coil spring would work, but could not find the year for the TJ.
Any suggestions welcome.
