if your TPS has a more than 3 pins it has a TPS idle switch.
i cant cant pins in the Parts list.
it must be closed at idle or idle dont happen.
and your maf is in the TB body, so any leaks up stream are just measured, no problemo.
righto l , egr tube at rear. and egr is electric. clean it.
cheer.s
http://www.kick-fix.com/
