Old 09-27-2009, 10:41 PM   #1 (permalink)
zookini is on a distinguished road
Default Have mixed up the fuel lines? need help
Hi all, i have had my gas tank replaced( my brother did the work) since then my charcoal canister is getting filled with fuel....have the lines been crossed up? do the lines from the vapour seperator both return to the tank or should one of the lines connect to the charcoal cannister line?....if i unplug the small vacuum hose from the cannister it does not leak.....can anyone help....Thanks Dominic
I have a 92 kick 1.6 8v 2-door auto
zookini is offline   Reply With Quote
Old 09-27-2009, 11:12 PM   #2 (permalink)
kick-fix's Avatar
does this help
http://www.kick-fix.com/
Old 09-27-2009, 11:48 PM   #3 (permalink)
Hi, it may help some but it does not show where the lines attach to the vapor seperator....right now i think my lines are going round in circles and not venting the vapours properly.....they are going from seperator and back to tank instead of being dispersed and the gas is being sucked up by the vacuum into the charcoal cannister.....unless there is some other problem with it....but everything was fine until we changed the tank
Old 09-28-2009, 12:58 AM   #4 (permalink)
ack
Try this link:
Ack's FAQ: Your 4X4 Portal To All Things Suzuki/Geo
It's for the '96 Tracker 16-valve but it might get you going in the right direction.
- Ack
Ack's FAQ
nearly 600 searchable links to the Samurai/TracKick
'88 Samurai Offroader
'02 Tracker ZR2 4-door Daily Driver
ack is offline   Reply With Quote
Old 09-28-2009, 11:22 AM   #5 (permalink)
kick-fix's Avatar
ack has it , as always.
