Old 09-27-2009, 04:45 PM   #1 (permalink)
obradleyo is on a distinguished road
Default cruse control
So i recently took the factory cruse control off my 95 kicker..... I know it is incorperated into my rigs vaccum system but where ? I was wondering if anyone knew where the cruse control get is vaccum from? I'm guessing that is open sence I have never done anything with it....
1995 Kicker 5 speed, 4 dr, 4wd, Ac,Ps 16v 31" TSL's,Calmini 3+3, torquer cam, magna flow with 2" tail pipe, calmini steering stablizer....... Sacramento,ca
obradleyo is offline   Reply With Quote
Old 09-27-2009, 07:03 PM   #2 (permalink)
I would install a T fitting at the brake booster hose.
The hose is large enough to get a good volume. Any other fitting is too small and could affect the accuracy for any vacuum activated sensor.
The other way, is drilling a hole on the intake manifold to install a decent fitting but you need to pull the Manifold to avoid metal shavings been dumped in the Intake.
Richard Craneum is offline   Reply With Quote
Old 09-27-2009, 08:32 PM   #3 (permalink)
if it was installed by suzuki where would they put it?
Old 09-28-2009, 12:14 PM   #4 (permalink)
kick-fix's Avatar
Default is it a VACUUM or Electric Cruise , my answer.
im still looking, cruise is seperate section in fsm and the vacuum , if any is not shown in the main drawings. PL or on main vacuum pages.
suz. and gm treat the cruise like a , forgotten orphan child. not even indexed. but is in section 9B. (missing 9B in my 95FSM, cute)
the 8 pages never once mention vacuum and all the parts are electric and the drive is a motor and does not use vacuum to drive a throttle servo.
nor does it sense vacuum.
the Cruise control module (brain) senses the VSS sender. (veh.speed sensor)
the cruise control motor has a clutch and is not engaged until you activate cruise.
ok , tell my why you want cruise to use vacuum?
that vauum would need to go to the Cruise controller in some fashion
but as you see the controller has only wires , so it might have a vacuum sensor but alais it does not.
FSM on flee bay is only a paltry $25.
did you check logo plates, maybe its NON OEM,
NOT STOCK, not factory supplied.
in whole or part.
http://www.kick-fix.com/
kick-fix is online now   Reply With Quote
Old 09-28-2009, 12:17 PM   #5 (permalink)
kick-fix's Avatar
a road map by mr, DBacon.
see top drawing.
see how it all works together.
Old 10-01-2009, 12:41 PM   #6 (permalink)
here is a photo of the CC also i found where it was it was the hose connected to the pvc hade a longe tube with a bolt it the end to plug it I worte all about it on my other post
Old 10-01-2009, 09:18 PM   #7 (permalink)
kick-fix's Avatar
that looks like aftermarket not OEM suzuki to me.
SCS/Frigette. SCS 3342/3365. Aftermarket Cruise Control SCS 3342 3365 speed control Frigette, SCS/Frigette, Specific Cruise Systems Factory Electronic Vacuum Electric servo GM, GMC, Chevrolet, Buick, Camaro, Chevelle, Toyota, Tacoma, corolla, camry,
SCS / Frigette - Climate Control Products for a World in Motion
SCS Frigette Quality Discount Cruise Controls at CarParts
ELECTRIC SERVO CRUISE CONTROL - JCWhitney
id contact the mfg and ask for install manual.
or search one out using google.
