Hi all,currantly have a 92 escudo 1.6 16V,the cylinder head is cracked and i need to sort an engine out,engine code is G16A,i need to know will the 1.6 16v from the 00 onwards vitara work in my escudo as in,are the cylinder heads and block the same so i can bolt my inlet and exhaust manifold to the newer engine???.as i may have one sorced.any help will be much apreciated.thank you.
I'm pretty sure that the block is the same, I believe that the camshaft is different because the GV has a distributorless system
I could swap over the cam shaft if thats the case and also on my engine the dizzy housing bolts off the end of the head,i wonder if its the same on the newer one.
