dash, remove speedo bezzle. with a few screws.
then you see more , then pull these.
now pull back on speedo head. , sometimes you can get hand inside gap and unscrew the light nuts. (look like knobs) other times you must disconnect the speedo cable
by tickling the lock gently it pops off.
also is see a panel that comes off below (i/o) cluster. remove that and look.
haz light , which one, each is labled?
i will guess at the BRAKE lamp.
sure, on most these cars there are 3 or 4 things that can turn on this lamp.
including the brake fluid level.
ever check you fluid levels.
there is a test, it level is ok.
manuals at suzuki or on fleebay. your market. country.
http://www.kick-fix.com/
