» Site Navigation
» Model Specific
» Buyers Guide
» Network Links
09-24-2009, 10:52 AM
#1 (permalink )
Gallery:
0
i need help
can any tell me where can i get a drive shaft for my suzuki sidekick sport 1.8 four door js
09-24-2009, 11:27 PM
#2 (permalink )
Gallery:
0
Local wrecker or a junk yard in your region would have one. Have a look in the yellow pages and pick up the phone to call around.
1997 Tracker 4 door 4x4 auto. WARN manual hubs.
Prince Edward Island, Canada (East Coast)
Other Toys:
1988 Hyundai Excel 4 door 5sp
1990 Arctic Cat Prowler 440
Giovanni 49cc Pocket Bike
2001 Rottweiler Female, Black & Tan W/Pink Int.
09-25-2009, 03:03 PM
#3 (permalink )
Gallery:
0
cant put in new u-joints?
front prop shaft or rear ( sure rear)
every sells the joints even suzuki.
http://www.kick-fix.com/
09-25-2009, 03:05 PM
#4 (permalink )
Gallery:
0
which shaft.
there are 4
09-25-2009, 11:27 PM
#5 (permalink )
Gallery:
0
i need help
my suzuki sidekick shaft has a center bearing in the middle.so can i replace it with one that has no center bearing in the middle.and by the way i've seen sidekick sport with a single straight shaft .
09-26-2009, 12:32 PM
#6 (permalink )
Gallery:
0
ok, rear drive prop shaft.
the question is really can you use a 2door prop shaft instead of a 4dr.
no , it wont fit. why would you want to.?
THERE ARE 4 PROP SHAFTS ON THE REAR , on sports alone.
2door, 4door, 2wd, and 4wd.
what is your question.?
do you want to buy the wrong one and cut it down? not sure. what you are asking.
UNZIP THIS and see what i mean.
this page is 1.8L only and only for 4wd.
09-26-2009, 01:02 PM
#7 (permalink )
Gallery:
0
Hot !!!! Miami beach condo's 1/2 off this weekend, only $500,000.00 to the first 10 fools
easy 0 % down fannie mae financing , Ninja specials.
Linear Mode
