Old 09-23-2009, 11:55 AM   #1 (permalink)
GoSlowGetStuck is on a distinguished road
Default Replacing valves - need machining?
89 Sidekick 8V, has one chipped valve and another burned one, so I ordered a set of all 8 intake/exhaust valves. If I use a valve spring compressor and replace the valves myself, and then use lapping compound and a lapping tool, will that provide a sufficient seal? I would like to avoid paying a machine shop to do a valve regrind, but I know in some instances it's far cheaper in the long run to have the machine work done. Thoughts?
GoSlowGetStuck is offline   Reply With Quote
Old 09-23-2009, 01:26 PM   #2 (permalink)
billsmartis is on a distinguished road
Dump a little gas down the ports and if the gas don't leak out the valve it's sealed or lapped properly.
Bill S.
billsmartis is offline   Reply With Quote
Old 09-23-2009, 03:26 PM   #3 (permalink)
Bill S.
Good idea, I'll give that a shot after lapping the valves and hopefully I can avoid the machining!
Brad - 89 Sidekick JX 2dr - Work in progress
Old 09-23-2009, 08:15 PM   #4 (permalink)
aquanaut20's Avatar
Check that your seats are not recessed too far before you spend time lapping. The angles may not be consistent with the new valves.
92 Ford Explorer, 450k
97 Ford Explorer, 360k
99 Tracker, 4dr, 4x4, 2L DOHC, auto 165k
Old 09-24-2009, 02:14 PM   #5 (permalink)
kick-fix's Avatar
a home valve job, ok, we will watch
take it to a machine shop?
they will do all the steps,skipping none,
skipping steps ,is bad. ( every time i try i get egg in face, 40years of mistakes)
1: pressure testing.
2:warpage.
3: cam bearing checks.
4: guides.
5: cut valves to match seats, to spec or to you spec (3 angle?)
6: new seals.
I have no hope for your seats. not after burning the valve.s
just my gut feeling.
$300 exhange or less if you get yours done and wait.
http://www.kick-fix.com/
Old 09-24-2009, 02:27 PM   #6 (permalink)
2:warpage.
4: guides.
6: new seals.
It's hard for me to spend $300 on a head for a $400 vehicle. Of course if I had money to throw at it then I would have no problem doing it right and taking it to a machine shop. Basically I was just wondering if there is a chance I can do it at home. I see the worst case being that it burns another valve in 1000 miles and then I'm out $60 for valves and a day or so of my time.
For what it's worth though, I'll call the machine shop and see what it would cost to rebuild it, if I supply the valves...
Old 09-24-2009, 02:31 PM   #7 (permalink)
aquanaut20's Avatar
LOL, I have been in the same boat, even cut my own seats in the early 60's.
Road rally with Volvo's, 544 and 122 (Canadian,4dr) and P1800, lots of fun.
http://volvo1800pictures.com/bros/oc...0-221-1800.pdf
as the saying goes, "Bin der dun dat!"
Old 09-24-2009, 02:41 PM   #8 (permalink)
aquanaut20's Avatar
Your other option is this tool,
32-1741 - Neway Valve Seat Cutter Kit
and if it doesn't work at least you have the equipment. This is similar to what I used 55yrs ago. I could not afford a mechanic when I started and could not get factory support.
I was the first to set a GM alternator on a Volvo to replace the generator set, it was unheard of in those days but I needed the power to run my Ham Radio set(it had valves as well, LOL).
Old 09-24-2009, 02:43 PM   #9 (permalink)
Hey, and it's only $421.65 So much for taking the cheap way out of this!
Old 09-24-2009, 07:41 PM   #10 (permalink)
When comes to cylinder heads and machining I shop around. Sometimes and I have seen, is cheaper to buy a reconditioned head with all the fixing for less, or outsource the job to a machine shop. This kind of work a Do-It-Yourself usually cost more, no because of the labor, is the tooling that does not makes it cost effective if you want to do the job right.
I bought 2 Cylinder Heads for a 3.4L V6 GM engine for around $500 at Auto Zone. So far is doing great and have a 1 year warranty. If I bought the pullers, valve seat, press and any other tools, to have the decent one it would cost me more than double. Beside, how often I will do the work to warrant the extra expense?
Anyway, good luck with your vehicle
Richard Craneum is offline   Reply With Quote
