97 Tracker 4 door 4x4 1.6L 16Valve Auto trans w/OD
My transmission will go into OD then reduce a engine RPM further 3 or 400 RPM when the torque converter locks.
Recently, the transmission would go into OD then lock up but come back out of lock up then lock up again as soon as it was under very little or no load, like when driving on a flat non hilly area. If it was under load or coasting it would seem to stay locked.
It has got worse over the last few days though, now it goes into OD then just shudders with each pulse lasting about 1 second. Putting the transmission into "power" mode will help a little but at highway speeds, it seems to have a hard time staying in OD.
It is going into the transmission shop tomorrow (Wednesday). That was as soon as the guy could get it in to work on it. I am guessing the cause is a warn out torque converter or a cracked valve body?
Any other ideas?
1997 Tracker 4 door 4x4 auto. WARN manual hubs.
Prince Edward Island, Canada (East Coast)
Other Toys:
1988 Hyundai Excel 4 door 5sp
1990 Arctic Cat Prowler 440
Giovanni 49cc Pocket Bike
2001 Rottweiler Female, Black & Tan W/Pink Int.
even a false , IN 4wd ,will do that.
low pump pressure.
one way to find out is to be sure that the TCC is dropping in the tranny
you need to monitor the TCC command line from the TCM (BCM).
tranny puter.
if the TCM is still commanding (12vdc out) to the tranny , then the problem is the TCM is deciding to drop it.
but then that begs why?
the TCM has many many inputs and if any are wrong then TCC drops.
the TCM monitors, at least, Load (vacuum) , Kick down (DEMAND) and tail speed (vss tach).
not to mention gear selector position. and throttle angle.
but key is the monitor the TCC drive out of the BRAIN.
if TCC is holding then the Tranny is messing up.
how is that. TCC 1a.
PS:
some cars ,many you need to plug in OBD2 scan tool and pull the tranny fail codes 4speed.
PS: OD lamp flashing warns of TCM faults.
if you need the tcc lock up chart with speed and throttle valve rules .
at low 10% TPS angles ,TCC happens at 30mph. ( and faster)
at 20% that moves to 38 mph.
at 30% 45 mph
at 40% its 48mph.
above 40% its total drop out , by the graph.
if od flashes i do have the flash code method of retrieving the errors.
FSM page 71-10a-14 (refr)
btw: the TCC command line on your TCM is pin 12, and is the Gren/yell wire and has NO RELY the new TCC has its own high power driver transistor,relays are for squids.
hahehehehe
Looks like the torque converter needs to be replaced. The transmission shop has it apart... They have located one and have it on order. I hope they have it finished soon. In the mean time I am driving a friend's spare ride - 1986 Grand Marquis. I am told I look like a pimp.
Other Toys:
