motor id.
how-to-find-EFI-parts
if the belt is 144k and the pump is 144k
just a fast looks tells one , its over the 70-90k range and is soon to fail.
the logic of this is , if doing a belt at 90k as many drag it out to , then why not replace the pump. its right there and easy as pie to do.
but taking out a factory pump and putting in a china rebuild might be not work out.
144k is lots of miles on any pump, belt and idler. way too many ,if true.
the 8v is Single point TBI injector motor, the 16v,is MPI , multipoint injectors x4.
the 8v says in fsm, to relax the valve-lifters, so belt tension can be set.
so on an 8v , a new gasket for VC (no, not viet cong) is in order. ahahahah
http://www.kick-fix.com/
