I have a '91 - dont know if set up is the same as yours, but my FSM indicates switch is in steering column. To get to it, you have to remove horn button, steering wheel shaft nut, steering wheel (with puller) upper and lower column covers and access cover, and there you are.
It should be under the dash by your ecu, may be behind it, some are by glove box. If you do a search kick fix had a diagram on here a little while ago.
id dont think my dwg would help,too many black glob objects.
if it clicks then just put a rubber tube in one ear and listen with end probing.
BINgo got yah.
but im near deaf other just point and say ,there. thats it.
