put new core in and new water pump and now no fluid is gettin 2 the core. the 2 lines goin 2 it arnt even warm. is there a passage from the back of the head i should check? need 2 find this b4 winter, its my winter truck.
awsome , thanks for the info and of course its a pain in the a$$!!
ill check it tomrrow
I have found that if you replace the core the system will air lock this is how I correct it.....
turn your heater on, with engine running, keep adding water as air is displaced...have the cap of radiator out... do so with a cold engine..keep running your heater at max. and just keep adding water at radiator..after several minutes all air will be out..you will notice that bubbles will stop and water will look calm at top of radiator orifice
this is SOP for any rad fill.
the heater has no valve so running it does nothing, the core has only a damper .
the water pump will force water out the rear port, thru the heater core and then back to the suction side of the pump. if the core is cold, its blocked or the pump is running dry. IMO
you could fill the block with thermostat out, and the put it in with the bleed hole FORWARD. .
this car in not known (oem) to need much burping. (no mods)
id fill it , with water then start it with the rear hose disconnected at rear of head.
most squirt like mad.
then put it back and pull the core return hose, i above squirts nothing in world can stop this test from squirting too. (no valves)
if all these tests pass, then the block (water jackets) are dry and your have a thermostat put in wrong or one missing the all important bleed hole.
my 2 cents.
got it. was the hose that connected part 20 to core. blocked right up with sawdust/sand lookin sh!t. all good now and wasent to bad to get 2. thanks
